I've decided to go with a 24v system for RV, but will still need 12v for a couple things. Looking online I see many many options...any recommendations for a particular unit or manufacturer? thanks!
Step-down modules
4400w, Midnite Classic 150 charge-controller. -
I have used a sealed Chinese units for over 6 years. I also use a couple non sealed adjustable units. None have failed except I had to have a big screen TV repaired from using a inadequate amp step down converter. They are cheap enough to try a few of them and decide what is most stable and best fit for your application. on the 10 amp sealed units, keep your load around or under 7 amps or add a cooling fan. 20 amp units add a fan for anything over 12 amps. make sure you use fuses.Comment
