Is lexan glass a good kind of glass for solar panels?
lexan glass for solar panel
My opinion, no. it lets water vapor right through, same as plexiglass. Same as 99% of all paints, silicone sealers and epoxies.Powerfab top of pole PV mount (2) | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
lexan glass
what is the best kind of glass i can use? I am building very large solar panels and need some cheap strong glass so what should i buy?Comment
People talk a lot about shower door panels.
Maybe you find the most reasonable size of glass and then set the size of the panel?
Russ[SIGPIC][/SIGPIC]Comment
