The Solaris in a quart kit has product that weighs 2.2 lbs / 1 kg - it works out to $ 35.38 / lb.
This material is a platinum-based addition curing silicone. In fact this type of formula contains a high amount of platinum, which enable the material to cure without outgassing, or giving off by-products the way acetoxy silicones cure.
So there is no deformation in the cured rubber over a long period of time; archival.
Possible encapsulation material?
This is a sticky topic.
You are correct.
I come as a friendly contributor; I am willing to offer my 13 years of industrial silicone experience to this industry.
But if my presence aggravates you or anyone, then I will stay away from the forum.
Honestly, I posted this to see if anyone would respond.
So I must apologize, but I do not know the exact price right at this moment as I am at home on Friday night 11;30 pm. We do have pricing though and it will be on our site shortly.
Off the top of my head, I can tell you it is VERY competitively priced - less than the DC material for sure.
I will post the price soon this coming week... if ok.
In the meantime,
Would you like to try some?Leave a comment:
Great thread. I have tried to make sense of making my own panels but the numbers just don't add up, and the slygard is a showstopper as it costs almost $1/watt.
I hope you guys come up with something brilliant and one that works on a plastic front, such as Lexan which is cheaper than safety glass.
One tip to get bubbles out of your mix jar is to use a vacuum sealer like they do for food, .... just takes seconds.
Such as: http://www.youtube.com/watch?v=R4Wk_0xVBbM
In use: http://www.youtube.com/watch?v=d4qdgQPTvn4
Here is a good vid on how they make panels commercially - using films rather than liquids:
TomLeave a comment:
slow dry is likely better, less stress developsLeave a comment:
So. I got that liquid nails clear seal all mixed together with the mineral spirits. I used a whole tube of liquid nails and and a pint of mineral spirits, half of this:
I put the mineral spirits in first, then I mixed in the whole tube of clear seal. I stirred it up, and then let it sit all night. The next morning some of the clear seal had settled, so I stirred it again, It resulted in a pretty good mixture, flowed probably as good as sylgard.
I poured the mixture kind of like that guy markp on youtube, like this:
I had the same layout, 4x9, But I went around the outside of the panel, then went down the middle, and then went across each row. Waited, A lot of the bubbles removed them selves because I only went around 3 sides of each cell. Then after most of the air was gone from below the cells, I went down the 2 remaining gaps. Sat some more for most of the mixture to get below the cells then I fished out the bubbles. With the little bit of remaining mix, I poured it over the backs of the cells.
It's been sitting for about 2 days, it's still a little wet below the cells. They weren't lying on the tube of liquid nails, It does a little while for it to dry. But, it probably doesn't help that the panel is in my basement. It's not exactly warm or sunny down there.Leave a comment:
But if my presence aggravates you or anyone, then I will stay away from the forum.Leave a comment:
Great!
Sure, I'd even do a test on it with my light meter.Leave a comment:
You are correct.
In the meantime,
[QUOTE=smoothbrad;11737]A 2-part platinum-based (Addition cure) room temperature vulcanizing (rtv) silicone rubber is most suited because during the cure cycle this material will not exude any by-products such as acetic acid and alcohol, both of which are associated with tin-based silicones.
Platinum based systems do not need to be thinned out with any solvents either, and are considered to be archival in the sense that they will not modify or change over time. SolarisLeave a comment:
The dap sounds like a good alternative. I was searching around last night and found some other possible alternatives.
Sashco (Sealants) 14010 "Through The Roof" Elastomeric Roof Sealant 10.1 Oz. - Clear
Sashco (Sealants) 14004 "Through The Roof" Roof Sealant 1Gal.
CRL Clear Dow Corning Silicone Glazing Sealant
Buy Dow Corning DC1C Clear Glazing Silicone Sealant online at DKHardware.com. Our Hardware, Tools & Sealants category offers a great selection of Neutral Cure Silicone Sealants products at the best price!
Elastomeric Epoxies
http://www.epoxy.com/elastomeric.aspxLeave a comment:
Elastomeric Epoxies
DrRobot,
Just checked the tech sheet on your DAP.
Sounds a lot like the CS, but with a better heat range.
Be sure to use a good respiratory, these materials have some pretty nasty stuff in them.
Oh, and be careful, DAP also has a clear silicone and I'll bet it's the type that would eat your cells.Leave a comment:
The plexi is perfect.
The mixture clears up, I've already tested the mixture on some other busted cells.
Good luck!Leave a comment:
