Is it ok to glue broken cell's . will they stand up ? .
Broken cells
Each cell needs to have a front side contact, and a backside contact.
Cells in series, need to be roughly matched in area, and contain a central metal ribPowerfab top of pole PV mount (2) | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
hi chuck and welcome to solar panel talk. I appreciate you joining.
I'm going to move your thread to the "do it yourself" forum, as i feel it would be better suited there.
thanks and i look forward to your posts!Comment
Thanks
I glued them with Elmers. I tested them and your right if the main is in tact and the back buttons are to, they work. Thanks.Comment
Glued broken cells....
I had a few broken corners & one broke into 3 pieces. I used electrical tape to piece them together primarily for cosmetics reasons. I still get voltage from the 3 piece cell, altho the center is nothing more than cosmetic. The tape hold fairly well, but you have to carefully rub the tape on the cell.Attached Files[url="http://solarpaneltalk.com/album.php?u=2072"]First panel 40 volts, 140+ watts[/url]Comment
two panels
I have built and put in service two 36 cell panels. Using on our motor home working well. Thanks for the input All.Comment
