That would be a good way of doing it, how many bottles of slygard do you think I would need for a 108 cell panel?
Epoxy for encapsulating cells (great DIY thread with photos!)
This is a sticky topic.
Well , let me think. My 72 cell is 64x34 and to do a panel half that size would take one slygard ( 20oz) I think that is what that size is. so I'm going to do two slygard then the cells and then two more. You know this is all kind of exsperamental. This will be the first time that I have done this size of a panel.Comment
Fascinating conversation! How does this Slygard184 encapsulate hardens does it feel rubbery when cured or hard like plexi glass? I once found a youtube posting of a DIY'er applying a substance that when it cured it felt like rubber. I think that substance would be the best but I didn't get the name of it. I'll try in finding the link and I'll post it here so give me some time to find it again.I had a change of heart about going solar because I had an eye opening debate with someone and he won! LOL!!
I wouldn't leave it altogether though, only use is it for charging up battery operated tools or to light up a shed or if I am going camping. I think solar panels are cool to have but not to run an entire house, it's not worth the money!
It is kind of rubbery but it's silicone. I had to tare a 4x4 panel i had down and scrap all the cell's off and I have some peices of the slygard covered cell's I could send you if you want to see for yourself.Comment
Yes sure if you have pics or video it'll be great to watch.I had a change of heart about going solar because I had an eye opening debate with someone and he won! LOL!!
I ment in the mail type of send. I could get a picture but it wouldn't really show you what ti is really like.Comment
Scheek great job on the panels. Did you ever find out the name or where to buy this epoxy? Also do you still recommend encapsulating with this method?Comment
Epoxies are NOT UV stable....[I]"Experience is the Thing of Supreme Value in Life."[/I]
[I][U][url]www.smooth-on.com[/url][/U][/I]Comment
I am sure would like to see you pictures also. I havenI hope I get longer life out of cells by encapsulating them in epoxy. I will have pics later. Since all the chatter about corrosion and such, I decided to use a 2 part epoxy.
How I did it: After completing my soldering I had my cells facing down on my glass. I then finished my wiring. I used scotch tape to cover all edges of the cells going both ways, horizontal and vertical. I then ran a strip around the outer edge. My goal was to prevent any epoxy running between my cells onto the front side of my glass.
I used a 2 part epoxy that required (1) small styrofoam coffee cup of one and (2) cups of the other. I mixed the two and poured over the cells making sure that I had overlapped onto the glass to make a good seal.
It's dry now after a few hours and it appears to have sealed it all. NOW I'm not as worried about air getting to my cells and corroding them. Still, I'm not sure whether to leave an air vent or not, since my cells are protected. Maybe Mike has a idea.
Anyway, I'm ready to put this sucker to bed.Comment
Do you know if your epoxy has any UV resistance? Generally, epoxy will yellow and degrade over time if exposed to UV.Comment
I contacted a company in the states called Epic Resins and asked about an Epoxy for solar cells, after a couple of discussions over the phone and an in person meeting with the area rep, they agreed to send me a free sample of a Polyurethane 2 part epoxy. It arrived a few weeks later and I mixed it up according to the Data sheets and a digital scale. I must of did something wrong, because after 3 weeks of low humidity, it never hardened. I actually had to throw out an entire 36 cell panel. It looked just like slime. Too bad, my bad. Should of tried it out on a smaller panel.Comment
Air tight panel?
Do all panels need to be air tight? forgive my ignorance, i am so new that I have materials sitting at my house (i'm in Iraq) waiting for me that I haven't seen yet.Comment
