17v Vmax NewPowa vs 18v Vmax Renogy with Victron MPPT
  • Naruto
    • Aug 2021
    • 25
    Hi,
    I am working a RV solar application with very limited roof space, the standard 100W panels won't fit. My goal is to have at least 200w panel on the roof so my panel options are as following. (due to AC unit shading, panels will have to be connected in parallel).
    (Vmax/Voc)
    1. Renogy 100w + 50w x 2(21.6v/17.9v), total of 200w. consistent Vmax and Voc.
    2. NewPowa 75w x 3 (17v/20.3v) x 3, total of 225w. consistent but lower Vmax.
    They will be used with a Victron SmartSolar 20A MPPT controller.
    #2 is my preferred config, as it provides 25w more and would be simpler to install and better aesthetics as well. But I don't know the 1v drop in Vmax would have any negative impact on output. My Victron MPPT charger requires Voc 5v over battery voltage to start charging and 1v over battery to stay in charging mode. My lithium battery (3.4x4) has 13.6v near full charge, so I am looking at minimal 14.6v Vmax and 18.6Voc, which is within 17v and 20.3v.
    But my questions is, in practice, would this reduce the duration of a day that I get solar charging from these panels? compared to Renogy panels which has about 1v Vmax over NewPowa?
    Thanks!
    What is the minimum MPPT voltage for the Victron ? 17.9V is barely enough voltage to charge with a cheap PWM controller, MPPT may need 25-30V to activate.
    • chrisski
      • May 2020
      • 577
      With that 17 volt panel, when its warm or cloudy or both, panel voltage can drop below the panels rating. I have 18 - 22 volt panels and have not had problems with them, but 1 less volt could mean the SCC won’t work. THe 18- 22 volt panel I mentioned is my observed output. THe panel has 18 volts on it.
        • 15192
        If those 3 panels are wired in series then the voltage below 17V is mute.
