I'm currently working on a DIY Solar UPS using ultracapacitors (check out ultracapacitors.org). At the moment, it's based on two Harbor Freight 45W systems (6 15W panels) and 56 2600F 2.5V Maxwell BCAP0010 ultracaps. I've been seriously thinking of ordering some of the broken 6x6 cells from Ebay to build additional panels for it. Along the way, I've had some ideas which I haven't seen explored anywhere yet:
Thoughts?
Mark
- Mineral oil encapsulation: Keep the panels in a tank of mineral oil. Mineral oil doesn't conduct electricity, it keeps moisture out, and the thermal mass could keep the panels cooler and run more efficiently, especially if coupled with a heat exchanger to dump the extra heat.
- Window tint: V-Kool makes some window tint (VK70) that rejects as much 94% of infrared (IRR) while still passing 70% of visible light (VLT). Might make up for the loss of light by keeping the panels cool. And if it was coupled with parabolic mirrors to concentrate the visible light...
- Connect cells without soldering: Looks like soldering all those tabs is a pain. I only need 2.5V, so my thought was to connect the cells in parallel using a 1/8" aluminum sheet on the back and 1/8x1/4" aluminum bus bars on the front of the cells using springs to provide enough tension for good contact without breaking the cells. I also thought about bending the aluminum into clips and again holding them in place with pressure. Wouldn't work for panels on trackers, but for stationary panels, it seems a heck of a lot easier for DIY.
Thoughts?
Mark
