Are DIY Solar Panels Worth it?
This is a sticky topic.
Redneck = DIY?
I believe that most members will take the time to research and ensure that the proper wire and connections are used. I'm wondering how many DIY members have started a fire with their solar panels?
Reading over the comments it seems that a number of members are against the whole DIY approach. Some even enjoying mocking other members who are simply trying to learn.
I've built several panels that I use to charge a number of batteries that run some general lighting, my security system and a pellet stove up in Vermont. My panels cost more than purchasing them off Ebay, but I used solid framing, low iron glass, Dow 184 and tedlar backing.
It's easy to buy and have someone else install, but let's try to be positive and support the members that are trying to learn the process.
Thanks,
JJComment
Information is out there if you take the time to research. It's helpful to have forums to discuss ideas and make suggestions.
It seems that a few members are only concerned about telling you that it's not worth the effort to build a panel. Before any member starts claiming that that they know better because they're an engineer, so are many of us that sucessfully built functional solar panels.Comment
Hi JJ - You misread and overlooked what is really being said -
1) Not many have the skills or tools to make first quality DIY
2) DIY can not be used for grid connect legally
3) DIY does not qualify for rebates/incentives etc
For the person that has the skills it is perfectly fine to do so. Just don't expect a DIY panel to have the life of a store bought name panel.
DIY is a fine science project.
DIY electrical work is not all that easy to do well and to do up to code - the DIYer will not even know what code for a particular task is.
Too many come along that have read a blurb on some green site and are now experts - that is so much BS.
The first solar installation that makes sense most places is solar hot water. That is far easier for a DIY installation and can be done well. It will save most more money than a small PV system.
Russ[SIGPIC][/SIGPIC]Comment
Russ - I agree entirely. These panels are expensive to make, even if done on the cheap. I've seen some instructions on "green" sites that will work, but I doubt the panels would last a couple of years in the weather. When I designed mine, I researched it, and decided that for the amount I was spending, it wasn't worth cutting corners.
However, now that I've done it once, I doubt that I'd do it again, when I can buy them cheaper, and probably get better reliability.
I'd give a warning - solar panel assembly is not a great place to learn electrical wiring and soldering. I've seen some video instructions on the net, and been horrified at the lack of skill. For those who haven't done it before, get some copper wire, good soldering iron, resin cored solder, and get some practice at it. It's not hard, but there's some technique and recognition of when it's working properly, which takes practice to learn. You don't want to be damaging cells, or getting poor joints.Comment
Disagree about misreading some of the negitive posts. I do agree that commercial panels are the easy way to go and provide the peace of mind for some (rebate helps). I've not reviewed any of the sites that sell instructions on building panels. My experience is from summer work while in college with a solar company over a four year period. I was taught by one of the installers on how to build panels and wire them properly.
I've built four panels that have been up in running in Vermont for the last 18 months. Found that the commercial panels would not put up with the weather in the Northeast Kingdom. Heavy snow loads and high winds are common. Commercial panels seem very weak in construction.
I'd rather build my panels (old school) instead of buying them from China.Comment
Well then that is a lot of double talk. On one hand you say:Then on the other hand you say:It seems that a few members are only concerned about telling you that it's not worth the effort to build a panelI agree entirely. These panels are expensive to make, even if done on the cheap.
However, now that I've done it once, I doubt that I'd do it again, when I can buy them cheaperMSEE, PEComment
Sunking,
I'm the one that stated "It seems that a few members are only concerned about telling you that it's not worth the effort to build a panel".
Russ was defending your position on the DIY approach.
JJComment
Sorry my bad. Russ, Mike, and myself are really trying to help and prevent folks from wasting a lot of time and money. I have consistently said building a DIY is fine for something like a science fair project, but for any real useful purpose it is fruitless adventure.MSEE, PEComment
well i built 12 150watt panels DIY style using NO sylgard type encapsulant and cheap glass in a double-pane setup and they charge a bank of 8 215ah golf cart batts into two 2500watt pure sine inverters .. it pretty much runs my whole house sans ac and dryer .. theyve been on the roof for several months now and so far zero failures, so the whole 'fruitless' thing is a matter of doing something that will work .. i agree dont waste time and money but there IS a way. For one, there needs to be a basic knowledge of electrical to be successful, yay you can solder but you need to be good, you need to understand voltage drops and wire sizes, how heat effects things .. basics .. thats first .. then one needs a design that considers the factors involved in a solar panel, heat, exposure to elements, how do i seal it so heat can radiate out and moisture can be blocked, that wont break down and will 'hold' ... plexiglass, wood, plastic are all things that dont work for a serious panel home build .. neither is a 200$ piece of glass cost effective .. neither is insulating the back of a panel and basically sealing the heat in conducive to performance ..Comment
Sunking - great information, however I have a few questions - not necessarily to be answered here, but perhaps worthy of consideration.
1. How much did it cost, compared to purchasing a system?
2. To be cost effective you need to get a couple of decades life. It's early days yet.
3. Has the system suffered severe weather yet - eg hailstones. I used tempered glass to allow for this. It happens rarely, but only takes one instance to wipe out thousands of dollars worth of panels. I've had all my skylights destroyed in a storm.
4. Damage of cells from air attack if not fully sealed may take a few years. Have you guarded against this, seeing you didn't use protective resin.
Congratulations on your achievement - I hope long term, it works out for you.Comment
not many photos but i did make alot of vids, although i suck at making vids
so far im happy with the panels. Luckily here in florida i dont see much hail and the few times i have its been pea sized but that would be a consideration in some places im sure .. i toyed with the idea of attaching a sheet of plexi on stand-offs to the front of my panels but it would drive the cost up 40-50 bucks a panel ...
Hi, I just recently joined this site after already starting my DIY project of building solar panels. After reading the majority of the posts it appears to me most of the people are against building your own system and steer you away from attempting to. Which is surprising to me since I had thought this site would be the complete opposite and the reason I had for joining. What is the point of having a site that gives the sense you are going to start your house on fire, or your panels aren't going to last, or you won't have a warranty, and you should definitely buy commercially made panels and have a company install them. I usually donComment
