DIY Eva solar panel build
This is a sticky topic.
Totally awesome, thanks for the link. This should be a "sticky".
This short article is also very useful about how panels degrade, these are factory panels,
I'd expect DIY to not be anywhere as good.
Required reading for all DIY panel builders !
http://photovoltaics.sandia.gov/docs...20Quintana.pdf
link dead, i think this is a replacement:
Oztules' series (at Fieldlines):
http://fieldlines.com/board/index.ph...,144982.0.html
http://fieldlines.com/board/index.ph...,144995.0.html
http://fieldlines.com/board/index.ph...,145004.0.htmlLast edited by Mike90250; 12-22-2018, 01:21 PM.Powerfab top of pole PV mount (2) | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
Free vacuum pumps
Some education required.Check the "net".
If more volume is needed maybe an AC compressor.Comment
