DIY Solar Panel Handphone Charger not working
I'd probably use something like a 1N4001 instead of a 1N4148. The 1N4148 is just a switching diode, it seems small for something like this. -
I believe your answer is correct. The charging voltage needs to be over 4 for a 3.7v battery system.I think That since the battery your using is 3.7V and the panel itself is 4V. The panel isnt charging the battery.
On a sunny day that panel might not be producing exactly 4V.
And when charging a battery you need like 5.5 volt. So on a sunny day if you test and see if you making over 5 Volts then it maybe charging the battery then.
But im not the one you should be listening to Im a Newb as well with this stuff.
You need more Volts charging A battery of a 3.7 caliberLeave a comment:
Guest repliedI think That since the battery your using is 3.7V and the panel itself is 4V. The panel isnt charging the battery.
You need more Volts charging A battery of a 3.7 caliberLast edited by Guest; 05-12-2016, 12:00 PM.Leave a comment:
by the way, i followed this tutorial online expect i replaced the 2x AA battery with an 18650 battery.
src : www.Kipkaykits.comLeave a comment:
Just found out that the diode is reversed. curse you diode!!!!!
So you're saying that i should strap 2 panels in series or parallel ? or buy a new panel ?You have to have a panel capable of ovderproducing what the charger can consume.Leave a comment:
Except for the fact that this CC requires a minimum of 6V DC and the OP does not have that.This one is MPPT Capable. These Are the droids you been lookn for.
http://www.ebay.com/itm/281881773155...%3AMEBIDX%3AIT
Guest repliedThis one is MPPT Capable. These Are the droids you been lookn for.
http://www.ebay.com/itm/281881773155...%3AMEBIDX%3AITLeave a comment:
your chip is not MPPT capable. It wants to have power from a voltage source, and a PV panel is a current source, so it nearly instantly overloads the PV, and crashes the voltage.
Batteryis dangerously discharged, beware, it may ignite after being chargedgot 0.2v on the batteryLeave a comment:
Guest repliedFrom my understanding those chips arnt used for solar. But it shouldnt matter. I have the same chips too.
I think maybe your solar panel is to weak to charge the battery. But Im not a expert on this matter I'd wait till Mike or someone like that to tell you what your problem is.
Here is the chip on ebay
http://www.ebay.com/itm/141870592094...%3AMEBIDX%3AIT
Input voltage: 0.9V-5V DC
Transfer efficiency:96%(max)
With USB port
With working indicator light
with one AA battery power supply output current can up to 200~300mA,
two AA batteries to the output current of 500~600mA
Oh, by the way the solar panel gets 5.5v on sunlight and gets 0.6v with the battery connected to it.Leave a comment:
So, I am currently making a diy solar panel charger with an 18560 2200 mAh battery, a cheap 5v 350 ma solar panel, a random diode i found on a toy electronic kit, and a step up 0.9v-5v to 5v chip thing. once i'm done soldering, i immediately put it outside of my house and let it charge. i left it for like 3 hours and i checked the battery using my multi meter and got 0.2v on the battery. it is not charging is it. can you guys help me found my problem ? oh, and here's some picture and a crappy drawing of mine
This gallery has 2 photos.
