Does Solar Cell move by Convetional Flow notation or Electron flow notation?
Conventional im assuming
Im trying to find like. A book on electronics, with water pipe analogy of Each electronic peices. like Caps, and JTEF, PNP's that kind of stuff.
Cutting solar cells
Guest repliedI know thats common sense. I know what Electron and Nuetron and Proton are and nuclieus. I am familiar with Electron flow. Scientific notation.
Bunch of stuff I learned in past month.
I didnt know solar Cells were just Electrons though. I thought they had neutrons and protons in them as well.
I.E.R TRiangle thingy.
conductors and semi conductors
Alot of the basics.Last edited by Guest; 04-03-2016, 10:50 PM.Leave a comment:
Think of the pv cell as a farm. The smaller it is the less it produces. In this case it will be less watts. Since the volts stay the same the amps must go down based on the formula Watts = Voltage x Amps.Leave a comment:
Guest repliedYep. I figured as much too. Although I didnt think it would produce that much Amps either. I wonder if you chop them up smaller you get smaller amps as well perhaps.Leave a comment:
I believe that is what I said would happen with your cell output.I checked out how much volt and amp the tiny cells make.
0.80A
0.55V
So I guess the cell remains almost as much volt as a larger complete cell. Just less amp.
If anyone interested in the cells http://www.ebay.com/itm/252340165663
You wont find them cheaper on ebay for 100pcs especially mono ones. Ive not seen anybody else sell mono ones.
Most times I see people sell photovoltaic ones for 15 bucks for 100pcs. also note that the conductivity pattern is not exactly the same on the front side of cells in yims pictures.Leave a comment:
Guest repliedI checked out how much volt and amp the tiny cells make.
0.80A
0.55V
Most times I see people sell photovoltaic ones for 15 bucks for 100pcs. also note that the conductivity pattern is not exactly the same on the front side of cells in yims pictures.Last edited by Guest; 04-02-2016, 06:20 PM.Leave a comment:
Guest repliedGreat Thanks.PNP's are a type of bipolar transistor. "Capcitators" (capacitors) store small amounts of energy and present a low impedance to high frequencies. Yes, talking to an electronics expert would be a good idea, although first it might be a good idea for you to decide what you want to do to begin with.
How about this:
Decide how much power you need/want
Decide what voltage it should be at
Tell us and we'll suggest a solar array to do that.
I do want to start a project soon with USB Charger. There is a set amount of volt and amp that the USB chargers run.
I bought these little controllers not to long ago. I think I will pretty much use small Mono Solar cells for these. I bought a bunch, they are fairly cheap.
I guess all I have to do is meet the 6-20V or 5V 2A requirement to make it function. And connect the leads to the Negative and Positive on the controller.
DC 6V-20V to 5V 2A USB Charger Regulator Solar Panel Fold bag
How about this:What if I made the Amps and Voltage Greater to the Mono Cells.
> unintended crack propagation
is going to get you. When cells are mfg'd, they are sawn apart with a diamond saw, laser cut, or water jet cut, After cutting, they are annealed, either in a furnace or with a laser. This keeps microcracks at the cut edge, from propagating across the cell which would ruin the whole thing, After cutting and annealing, they have the leads silk-screened on, then any coatings applied. Cells which break from handling, or you intentionally cut, will not have the annealing treatment, and chances are good in a couple years, cracks will grow and ruin them. But it's all for fun and learning.Leave a comment:
Ive been reading alot On electronics myself. If there is any great tutorials on it please share. Ive just been picking randomly through google on electronic manuals and printing them and reading them. Ive read over 300 pages in past month.
So Here are some small cells both garden lamp cells and epoxy and other. Different various readings.
So Say we use 23 pcs. of 1.20V x 0.30 amp. To make more than 6.80Amp Mono solar cell but adding- 27.6Volts through mono cell. And having diodes etc.
Does that make sense?
Think of it as like a set of blocks with a specific height and width.
So you have 23 blocks that are 1.2 tall and 0.3 wide.
You can rearrange them to be 23*1.2 tall and 0.3 wide.
Or to be 1.2 tall and 23*0.3 wide.
But if you want 23*1.2 tall and 23*.3 wide you need 529 blocks.
If you want 5 tall and .9 wide, you'd have more than enough blocks - but they don't quite come out to exactly that - but you can use a saw (DC-DC regulator) to get it to be exactly 5. And like sawing wood/plastic, you'll lose some of the area (power) in the process. (I admit the DC-DC regulator is stretching the metaphor a bit)
Hopefully you can see from this why you can't get 27.6V*6.9A (190.44W) using only 8.28W (23 * 1.2V*0.3A) of solar cells
Often water is used as a good electric circuit analogy - but I think the visualization of blocks is probably best for this basic explanation.Last edited by foo1bar; 04-01-2016, 09:15 PM.Leave a comment:
Guest repliedIve been reading alot On electronics myself. If there is any great tutorials on it please share. Ive just been picking randomly through google on electronic manuals and printing them and reading them. Ive read over 300 pages in past month."Can you draw me schematics of this DC DC Converter"
I could find one - I don't think I could do a very good one from memory. But generally people just buy a DC-DC converter.
I think you need to back up a bit.
Start with "I have X number of cells each doing ~Y volts and ~Z amps. Together they will output about X*Y*Z watts. I want to have N volts with M amps. Is there a way I can combine these cells to get N volts and M amps?"
If N*M is less than X*Y*Z, and N Is some multiple of the cell voltage, there's probably a way to do it easily.
If N*M is less than X*Y*Z and N is not a multiple of the cell voltage, then you may need something to convert the voltage (probably at a cost of 10-20% of your power, and requiring you to spend a few bucks)
And I'd recommend spending some time learning about electronics and conservation of energy. Voltage * amps * time = energy. You can transform it (ex. more voltage, less amps with some lost to heat in that transformation by the DC-DC converter) And you can store the energy and use it over a shorter or longer time via batteries
But you won't get 200W out of 20W of solar cells.
I don't know a good electronics book/online-course - I'm sure there are some out there, but I don't know which ones are good (ie. engaging and informative)
Does that make sense?1 PhotoLast edited by Guest; 04-01-2016, 08:27 PM.Leave a comment:
I don't know a good electronics book/online-course - I'm sure there are some out there, but I don't know which ones are good (ie. engaging and informative)Leave a comment:
Guest repliedCan you draw me schematics of this DC DC Converter Becuase frankly, I dont understand what you do with them in solar cell configurations of series and parallelLeave a comment:
Guest repliedPerhaps I should talk to A electronics expert.
You saying not even PNP's or capacitators. or something in that nature wont work?
Im not trying to TRoll just lookn for solutions or suggestionsLeave a comment:
Not threatening, just speculating.
Basically, rather than use DC to DC converters to get a compromise voltage from a mismatched set of cell configurations, why not just put the cells together into a compatible group in the first place.
One large mono cell is not going to be useful for anything, no matter what you combine it with. A group of 36 or more identical cells of this type could be made into one panel to charge 12V batteries.
Or 4 of them cut up into nine pieces each to make a small 36 cell panel.
Just don't try to mix the two setups unless you can match either the voltage or the current between them.Leave a comment:
