eva
============= Hello Bratan., from all that I can see/read/done/ it is only the Front of the cell that has to be protected from weather and air.So after encapsulateing the cell in what ever material, you shouldn't even need a backing.The backing is more for protection.All mine are doing well.And the last panels i didn't even coat the front of the cell, or encapsulate the cell, and they are also just like the first day. Like I said I do it the same way as a thermopane window, with silica in between the glasses. edges sealed with sil. and with an Alu. frame. I also put sil. on the inside of the Alu. frame when I put it together.
John
John
