My charge controller shuts me off at 11v loaded, so if the battery were measured in unloaded voltage, it would probably be, 20% discharge and off it goes. Good feature.
The advise on the 10% match of the battery to solar panel amperage output sounds good. So I guess if I had a 100ah battery, I would need at least 10a coming in from the panels to get the battery solution boiling good enough to keep the battery in good shape.
80 3 X 6 cells two panels battery requirement
I'm allowing for 20% discharge from full, daily. If you have 2 cloudy days, you are now down 40 or 50% from full. When you go below 50%, it really begins to impact the lifetime of the batteries, so you don't want to plan on regular 50% drawdowns.Leave a comment:
Mike that was very helpful. I try to not discharge my battery no more than 15% ( somewhere around 12.5v) because it takes too long to recharge it back to full. It seems like the deeper the discharge, the slower the rate of recharge too.Battery sizing.
First, determine your loads. Then you only want the nightly load to deplete 20% of your battery. So that gives you a size.
Then you want your solar to be able to recharge the battery from 50% dead to full, in one day, running all the normal loads too.
And the charger needs to be able to supply about 10% of the battery's capacity rating, to insure a well agitated electrolyte.
Then you must assume that your will get only 80% of the spec output of the cells.
Now you can order the cells and build your panel.
I assume when you say dead battery, you mean discharged 20%.Leave a comment:
moving this thread to "Building Homemade Solar Panels" forum
Battery sizing.
Now you can order the cells and build your panel.Leave a comment:
Hello and welcome to Solar Panel Talk!
I moved your post to a separate thread. Thanks for joining! Someone should be with you shortly.
I am planning to build two panels with 36 3 X6 cells for each panel, what battery I should choose? this will be for an off grid power. thanks!
