I have this idea
  • SolarFox
    • Oct 2015
    • 27
    I have this idea
    I would let to set up solar powered sprinkled. I am not sure if that is a thing or not but I would love to see if I can do it. Now, I know very little of the maths when it comes to building a panel, would if be a good idea to find a smaller panel and build off of it or should I build my own?
    [URL="http://greentumble.com/"]Greentumble[/URL]
    As a genera rule, except for small panels that have to be constructed to fit into a particular odd space, it does not pay to build your own panels.
    That can be fun and educational, but should not be seen as the inexpensive route to a working system that will last.
    I believe that there are commercial sprinkler controllers that use solar cells and a rechargeable battery instead of replaceable batteries or grid power.
    So it is practical as long as the valves are low power consumption.
    • SolarFox
      • Oct 2015
      • 27
      Well thanks for your input. That does make sense. I mean for the amount of time I would spend building one it would probably be easier to just buy one.
      • Naptown
        • 6880
        and in all cases more durable and likely less expensive
        • SolarFox
          • Oct 2015
          • 27
          yeah. I get these random ideas and invest half way only to come the the conclusion I wasted money doing things I didn't need to lol
            You'll fit right in here.
            • Amy@altE
              • 1023
              Depending on what you want to sprinkle, a SHURflo 2088 pump and a 100W solar panel could do the trick for less than $300.
              Solar Queen
              altE Store
              • SolarFox
                • Oct 2015
                • 27
                Based on what I was reading I was looking at spending more than that for an "idea" haha thanks I will check this out. It isn't a huge yard but I go out of town each week so it helps.
                  • 5242
                  Its EDUCATIONAL, not wasted. Just so long as you don't go broke or hurt anyone. Bruce Roe
