Turning a solar powered pool light into something else.
  • LeninaMors
    • Sep 2015
    • 3
    The pool store that I work at has a bunch of solar panels, this one:
    They are on clearance for really cheap. So I took one home to try and tinker with, then stashed some more in my office.
    However, I don't know anything about solar power. Or electricity. But, I'm pretty handy.
    Is it possible to turn this into a plug to plug a lamp into? Or a cell phone charger? Or use it to power rope lights?
    I was thinking I could put it outside my kitchen window, then use it for a rope light under the counter.
    Or maybe outside my bedroom window for cell phone charger or nightstand lights.
    Like I said, I'm not sure how any of this works. But one thing I do NOT need is a pool light. So, any alternative suggestions would be awesome.
    I also wonder if they can be chained together somehow, to supply more juice to whatever I can plug into it.
    Note: I do not have the pool light, this is just a conversion kit for a separate product that's battery powered.
    Thanks for any insight!
  • LeninaMors
    • Sep 2015
    • 3
    Here's a pic I took of the innards of the light. There seem to be 2 batteries, about the same girth as a AA, but longer.
    • PNjunction
      • Jul 2012
      • 2179
      ..... <snip> .....
      Maybe there is a reason that they are discontinued by the manufacturer, have no reviews, and are certainly questionable at this point. No wonder your employer is dumping them.
      The first thing to know about solar power is that there is a HUGE sales demographic to target with junk toy playthings.
      Instead of buying toys, buy a TOOL, like a P3-International Kill-A-Watt meter to start measuring stuff you'd like to power with solar. Armed with some knowledge, you can spend your money on quality items instead of just winging it with toys.
      • LeninaMors
        • Sep 2015
        • 3
        I appreciate your input. And while at some point, I would definitely like to get some more serious panels going, it's simply not in the budget at the moment.
        I'm buying a new house, and I figured that these little panels might be a good opportunity to get my foot in the door and familiarize myself with the process.
        If I just straight into a giant project, I feel like I'll either have to spend a ton of money to get something done professionally, or end up with a lot of costly trial and error.
        The little panels seem quality enough, so I was hoping to get a chance to tinker before getting in over my head.
        But I guess that's not the case. Again, thank you for the input.
        • PNjunction
          • Jul 2012
          • 2179
          The problem with the stuff at that low quality level is that you'll never learn anything. You will get frustrated, and your foot will go through the door. When a problem crops up, you can't trust that the pieces are actually working as they should. Toys.
          Thing is, solar IS costly, no matter what. BUT if you want to learn ....
          Perhaps this small project might help you out. I've tried to keep the costs way down, and still be somewhat useful with a a good deal of quality for their price range. The task at hand will be to just keep a 40-60w equivalent LED / CFL bulb burning for 10 hours to help get through the night. Use your favorite lamp fixture.
          You might want to gather up these essentials:
          1) Amprobe AM-510 multimeter
          2) Renogy 50 watt 12v monocrystalline solar panel
          3) Morningstar Sunsaver 12v / 6A solar charge controller
          4) Samlex SAM-250-12 volt, 250 watt DC to AC inverter (careful, this is now 115v ac like from your socket!!)
          5) UBG 12220 12v / 22ah agm battery or similar. Don't go with fly by night outfits that will sell you an old one...
          6) Battery Tender 1.25A battery charger, either model 021-0218, or 022-0185g-dl-wh (the latter is the latest CEC high efficiency model)
          The Battery Tender ac charger will help you get off on the right foot by ensuring that the battery you get will actually get a full charge from the outset. This is very important, and of course can be used when there is no sun.
          The UBG12220 is a pretty common ups-style agm battery, but there are similar little agm's like CSB EVX12200, PowerSonic and so forth. Just beware of deals too good to be true. Try to go reputable.
          Samlex is a quality inverter, and is what will drive your LED / CFL bulb for 10 hours. Try not to exceed 10 hours from one of these fully charged batteries. That will give you the longest life.
          The Morningstar charge controller is of high quality in this price range, and you should remove the "jumper" for these agm batteries, even though the silkscreen says "flooded", because in THIS instance, this product's voltage with the jumper removed matches the requirements of an agm better.
          The Renogy 50w solar panel is of relatively decent quality for the inexpensive end, and should recharge the battery IF you have 4-5 hours of good solar insolation. This means 4 hours centering around noon +/- 2 hours each side, and is NOT total sunrise to sunset hours. We don't know where you are, so if your hours are worse, especially with winter coming up, consider beefing up the panel to an 80W - 100W panel.
          If it doesn't fully charge during the day, we'll pretend that the Battery Tender is a generator in disguise, and use that to finish! Either that, or burn the bulb for an hour or two less. Conservation is the *cheapest* and most effective route to savings!
          Last but not least is the all-important multimeter mostly for measuring DC voltages. Don't get a shirt-pocket model. An auto-ranging meter like this Amprobe in this price range should suffice to get you started. THIS is where you will learn the most as you watch voltages during the charge / discharge process, do simple "rested" SOC battery terminal voltage readings to ballpark your state of charge, and the like.
          It seems like a lot, but at least these are products that are quality enough not to make you question if anything is working in the first place. From here, you'll have the knowledge to make more informed purchasing decisions in the future based on your needs (the Kill-A-Watt meter is very useful for this), along with this forum's guidance.
