Has anyone tried waterproofing / semi-encapsulating a solar panel by just having the EVA lined in the periphery of a series of solar cells?
Instead of having the EVA sandwiching the cells, rather, cut out strips of EVA and lay them in the periphery of the glass surrounding the solar cells. Then, using a heat gun, 'cure' the EVA. Theoretically, that should create an airtight seal, without the bubbles and need for a vacuum. Can also save money on the amount of EVA needed.
Thoughts?
Thoughts?
