Sorry for my empty post, had to make sure that i could post before i decided to write the deleted post all over again.
I live in china, solar panels here are more expensive than i first thought. Anyway i want to try to make a system that can charge my A/C which eats 2000 watts.
From chinas ebay (taobaoDOTcom) i only find three products which have good reviews, and are affordable. I hope someone could help me decide which on to choose. all the panels here are high in voltage and low in watt output. Most have a ratio of 4 to 1.
Here are the specs of the panels i am considering (they will be connect to make a big panel, and it will be used with a battery, inverter and controller).
(1) 0.5w 1.5v 2$, (2) 2w 5v 5$, (3) 1w 5v 2,5$
Could i make a panel that consisted of a combination of all these three?
I am leaning towards nr 1. That panel is flexible so i will be able to bring it back home in 2 years.
How many of that panel do i need run my A/C? And anyone know why all the panels here have bigger voltage than watt outout?
