Need help on solar power charger
  • Kyosoul
    • Dec 2013
    I plan to build a solar power charger able to charge any devices and especially laptop
    I know that laptop need average 12V input to charge
    I plan to build a battery pack but I stuck on how to wires to get the most mAh and V output
    I'm going to buy 8 AA 3.7V 2600 mAh battery and connect 4 in a series and 4 in a parallel circuit and connect both to get 14V output from battery and storage is about 10000 mAh .
    It is possible for this to work out?
    What size and voltage solar panel do I need
    Is that 12 volt figure specific to the laptop you have? Most these days use a higher supply voltage (18-24 volt) so that they can use only a series combination of readily available cells in the battery.
    If you can find a power supply for the computer which is designed to run off 10-14 volts DC (automobile use) then you do not need to know what the computer battery itself needs.
    Your idea about putting 4 in series and 4 in parallel is not a valid system.
    The best you could do is make two series strings of 4 each and put those in parallel. That would give you 14.8 volts at 4200mAh.
    And if you know that little about electricity you will be building a bomb by putting that many Lithium chemistry batteries in series without a proper battery management system.
    (Are the cells you describe called 18650s? Are they labelled as "protected"?)
    I do not think it is safe to try to help you at this point. Sorry.
    If you use NiCad or NiMH batteries at least it would be safer.
      No that is not true.
      None of this makes any sense. Since you mentioned 3.7 volts I can only assume you are talking about rechargeable Lithium batteries, and your laptop uses 4 Lithium cells in series for a 14.8 volt pack. Most laptops use 11.1 volts or 3 cells.
      However Lithium batteries do not come in AA package. For laptops they use Pouch packs which means they can shape them into any cubic area.
      Anyway all that means nothing for building a solar charger to be used on laptops. The best and easiest way if to use a 12 volt battery solar panel, a charge controller, 12 volt lead acid battery, and a Laptop Power brick made to operate on a 12 volt battery.
      The size of the panel and charge controller are determined by the size of your 12 volt lead acid battery. In this application you want to use a AGM type battery so they can take high charging currents of about C/4. So if you have say a 12 volt 10 AH AGM battery you want to charge it up at 2.5 amps. To do that requires a 50 watt solar panel and a 3 to 5 amps PWM charge controller. You then use a 12 volts DC Power Brick to charge your laptop internal Lithium battery.
        This is into silly and very dangerous land - thread closed.
        Never try what this poor fellow is looking in to!
