6100 is nothng new, and has been discussed and used at this site before. It's also highly tramissive to water vapor, as are nearly all silicones
http://www.dowcorning.com/content/pu...06-1016-01.pdf page 3.
It relies purely on there being excelent adhesion between the cell and encapulsant. fingerprints, dust and solder residues all defeat this adhesion, and at the worst place for moisture to gather. Since most DIY's don't even clean solder flux residue off the cells, all those areas are going to get damp.
You are free to build and connect as you wish, but don't give out advice as "gospel" to others, unless you are willing to back it up.
Again, most silicones are water vapor transparent, and moisture will collect in any unclean area where the silicone can't bond well. Without industrial cleaning, DIY panels will have residues, and therefor, failures.
