Hi I' trying to find the proper connectors for Evergreen ec-110-e . I ordered mc4 connectors but they do not fit the connectors on the panels. Any suggestions? Thanks, -Bryan
Evergreen solar panel connectors
From a quick tour of Google, these appear to be an older panel with a junction box on the back that contains terminals for direct wiring. AltE store site says they can be used in 12v or 24v configuration ( in pairs ), but also recommends a bypass diode be wired in when using as 24v.
I would assume you'd simply order the same type of wire you have on the extensions with the MC4 connectors, and wire them direct from the panel junction box to your combiner box, or whatever. -
Did they come with connection wires? They may be MC3 or Tyco connectors which look similar but will not connect.NABCEP certified Technical Sales Professional
