Here are some pics of my home made solar tracker. I still have to mount my 3 cell array to it and get the controller made. But this may give others ideas. I used 2 car window motors and combined the 2 gearboxes. I used an old front auto rotor with the tapered bearings and mounted it to an old chevy small block flywheel. Then I got a starter gear and mounted it to the gear box. I have the gearbox on a pivot so that I can disengage it if neccesary. I used the inner portion of a rim and weled it to my frame. then I got a small tote to cover the gearbox. In the test I took it runs very slow. It takes 20 min to rotate 180 Deg.
My Homemade Solar Tracker
Homemade Tracker
Here are a few more pics to complete the picture -
Awesome. Wish I had your skills for the mechanical side of things.Powerfab top of pole PV mount (2) | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
NICE!!!!Here are some pics of my home made solar tracker. I still have to mount my 3 cell array to it and get the controller made. But this may give others ideas. I used 2 car window motors and combined the 2 gearboxes. I used an old front auto rotor with the tapered bearings and mounted it to an old chevy small block flywheel. Then I got a starter gear and mounted it to the gear box. I have the gearbox on a pivot so that I can disengage it if neccesary. I used the inner portion of a rim and weled it to my frame. then I got a small tote to cover the gearbox. In the test I took it runs very slow. It takes 20 min to rotate 180 Deg.
I could not see electronics and actuator to drive the frame. Is this single axis or dual axis drive type ?Comment
Tracker axis
This is a single axis drive and I am using a circuit board with a programmable chip with auto return at darkComment
You will never get any useful power out of a windmill that close to the ground!
Looks very nice. What angle are you going to tilt the panels to? And will that be adjustable seasonally?SunnyBoy 3000 US, 18 BP Solar 175B panels.Comment
I have my panels set at. 41 deg for autumn and winter and change to 30 deg in summer. I use the MTM Scientific tracker circuit set to check for sun location every 5 minutes. If you need more pics let me knowComment
Very nice
Outstanding job Slidegate. I have been sketching out something similar but hadn't considered a rotor. I may have to go back to the drawing board.Here are some pics of my home made solar tracker. I still have to mount my 3 cell array to it and get the controller made. But this may give others ideas. I used 2 car window motors and combined the 2 gearboxes. I used an old front auto rotor with the tapered bearings and mounted it to an old chevy small block flywheel. Then I got a starter gear and mounted it to the gear box. I have the gearbox on a pivot so that I can disengage it if neccesary. I used the inner portion of a rim and weled it to my frame. then I got a small tote to cover the gearbox. In the test I took it runs very slow. It takes 20 min to rotate 180 Deg.Comment
