Hello all,
I am new here and would like some advice about my new system
I have:
three 136 watt Unisolar flexible solar panels each voc 46.2-42.2 They are supposedly for either 12 or 24 systems. http://www.soldonsun.com/files/UNI-PVL136.pdf
two 100 ah 12 volt Ocean sealed lead acid deep cycle batteries to be wired in series for my
24 v 1500 watt inverter
I also have a Morningstar MPPT Sun Saver 15 charge controller. Max open circuit voltage 75 v Battery Voltage Range 7-36 volts
• Nominal Maximum Operating Power*
12 volt battery 200 Watts
24 volt battery 400 Watts
http://www.morningstarcorp.com/wp-co...ENG10_1111.pdf
My question is whether or not my charge controller is strong enough to wire the 3 panels in series and if that is even necessary. I get approximately 4.5 hours of sun in my zone however it is a bit shady part of the day due to some tall trees. I may get either a stronger charge controller and probably another battery in the future. Would I be able to get just as good battery charging by wiring the 3 panels in parallel in low light Winter conditions ? Also, do I need to vent my battery box for sealed lead acid batteries?
thank you in advance
I have:
