can someone give instructions on how to install these where i can use an inverter to switch to household USA plug in appliances. please give details as to what the mc3 cables connect to and what other items do i need to make this thing work. this solar panel has been sitting in my garage and because i do not know how to install it so that i can run fish pumps outside. i dont want to use a battery so please let me know what type of inverter/converter do i need, and how do i hook up the cables.
Peel & Stick 144 watt Uni-Solar ePVL144 Solar Panel Flexible 24v Unisolar
Did you pay $299 for an Amorphous panel?!can someone give instructions on how to install these where i can use an inverter to switch to household USA plug in appliances. please give details as to what the mc3 cables connect to and what other items do i need to make this thing work. this solar panel has been sitting in my garage and because i do not know how to install it so that i can run fish pumps outside. i dont want to use a battery so please let me know what type of inverter/converter do i need, and how do i hook up the cables.
To answer your question:
just cut off the MC(X) cables...
then wire inverter directly ( +to+ & -to- ) to panel...
then plug in appliances... done.
Then, after you've done that (your way), you'll realize you need a battery and charge controller to have a functional system.
A dcv to acv inverter will not function directly from a panel.
Also,
you'll need to calculate the load (appliances) to determine if you have enough panels and correct sized inverter...
and obtain the correct battery and charge controller.[CENTER]SunLight @ Night[/CENTER]
