I just set up a small 45W solar system we are going to use to power fans in our greenhouse. It is one of those you can get from most tool stores that comes with all of the cables and regulator etc.. It comes with a regulator with a 12V DC female car-style accessory plug and another just like it marked for the inverter. We are using two small 12V fans and the instructions say you can plug a 12V accessory into the receptacle marked "inverter". So we plan on plugging both of the small fans into the two female receptacles.
What my question is, is that since we only want the fans to run during the heat of the day, do I really even need a battery? The voltage regulator that came with it seems to be all I need unless I want to store power and use it when the sun is gone. I have read about the need for capacitors etc. to regulate power flow. Is that what this voltage regulator will do?
The fans consume 8.5 watts each, so I should have plenty of power for them as long as the sun is out, which is when I need them to run.
Am I correct in this assumption?
Thanks for any insight you can provide and greetings from East Texas.
