Page 1 of 2 1 2 LastLast
Results 1 to 10 of 16
Thread: How to build a 1000W of power output
    May 2010
    1
    Default How to build a 1000W of power output
    Greeting from Chile. I am new in this area, Please could you help me in this request. I am building my own solar energy system. I only need 1000W of power base on 12v volt.
    Can you tell me onw many watts of panel do I need.
    How many amperes needs the controller charger
    How many watt do I need for the converter
    and how many batteries do I need for the bank.
    All comment are very wellcome.
    thanks in advance
    Aliropm
    16,087
    Well your question does not make much sense. If you need 1000 watts out from the panel, then you need at leat a 1000 watt solar panel.
    I think you are mixing up power and energy.
    Watts = Power at any given moment in time and is an instatanious measurement or expression.
    Energy= is the amount of power over a given amount of time. In electricity it is expressed as Watt-Hours. Watt-Hours = Watts x Hours
    I guess sunking is saying is for how long do you need the 1kw for.
    I also thinkI am new to all this too but that would fall onto the size of battery pack you have set up, providing your solar panel can suply the correct amount energy to keep battery pack charged for night time use?
    Solar Skipper
    657
    Quote Originally Posted by BuzzBuds View Post
    ... would fall onto the size of battery pack you have set up, providing your solar panel can suply the correct amount energy to keep battery pack charged for night time use?
    [QUOTE=MarineLiner;9488]
    Solar Skipper
    657
    - try and aliminate as much on battery dependacy is a good policy but I am not talking about a large just 2 of them how else will you store the power to use after dark? or are you just sujesting that he should not use the radio at night?
    16,087
    Solar Skipper
    657
    Well battery efficiency is around 80 to 90%.
    Pump back tanks are on the order of 25%.
  9. #9
    16,087
    Actually it is quite old technology and used by hydro electric utility companies. During power generation using dams, you take the unused generating capacity to run pumps to pump water into a lake to later be released and generate power again.
    Same thing can bee applied with a elevated water tank. You pump water up in the tank, and release it later to generate electricity. Sound cool but really inefficient.
    Jul 2009
    10,366
    Plus the volume of water required per kW generated is rather large.
Tags for this Thread
