Esun
For some reasons your posts are being cut off after only a few words. Try not to cut and paste your post or use character like an '.
New Sunpower NGT panels in 2019 vs X-series now
[QUOTE=Esun;n382979]
Haha wowLast edited by ButchDeal; 08-24-2018, 05:28 PM.Leave a comment:
I'd suggest Esun come up with some real logic and experience to support his claims or he be prevented from spreading hearsay and what's little more than advertising and marketing hype.
Opinion is one thing and this is one place for it, particularly if it diverges from the mainstream. Everyone has opinions and every one is entitled to them. But having an opinion says nothing about whether or not that opinion fits reality and practice, or if spreading loosely formed opinions can cause harm or perpetuate the spread of incorrect or dangerous or just plain wrong information.
From where I sit, and not simply because I disagree with him, Esun's opinions look uninformed and lacking the benefit of education and experience. As such, spreading such uninformed and inexperienced information around is at worst dangerous, and at least inconsiderate and rude. He's acting as a shill, but I'll give him the benefit of the doubt, be kind, and speculate he's unaware of acting as a de facto shill and call simply call him unaware and out of his depth, and due mostly to what looks to me to be the ignorance of youth, coupled with an overinflated sense of his own importance.
Bottom line : For me, treating opinions like gospel or truth as Esun seems to be doing is, IMO only, a deceptive practice.Leave a comment:
If you give our new member enough rope, he may hang himself. Bruce RoeLeave a comment:
You are very confused.Haha wow efficiency has nothing to do with production. You better write a letter to every Solar manufacturer and let them know they have all gone down the wrong path. It turns out there is no difference in production even if the amount of sunlight your turning to electricity is raised a few percent more and more kwh hours doesnt mean zip nada.
Efficiency has nothing to do with production. Efficiency has to do with area required to generate a certain amount of power. In locations that are space-constrained, more efficient panels can give you more power. In locations that are NOT space constrained, less efficient panels can produce more power for the same cost.
Exactly. Wouldn't you sound stupid if you said "hey, that car is really efficient, it must produce a lot of power!"The engine analogy you used is inverted we're talking production or power, just because 2 cars are 4door sedans it doesnt mean they produce the same amount of horse power/energy.
Efficiency and energy production are not anywhere near the same thing, nor are they even closely related.
That's right. Panels degrade at different rates. In fact, the more efficient panel may degrade faster than the less efficient panel, depending on the process used - in which case you would be better off with the less efficient panel.And a 5kw doesnt produce the same as another regardless of panels used, especially after 5-10 years.
Well, LG certainly seems to be innovating with each generation (Neon, Neon2, NeonR, etc). Panasonic not so much. Essentially the same product Sanyo invented some 8-10 yrs ago.Leave a comment:
Haha wow “efficiency has nothing to do with production.” You better write a letter to every Solar manufacturer and let them know they have all gone down the wrong path. It turns out there is no difference in production even if the amount of sunlight your turning to electricity is raised a few percent more and more kwh hours doesnt mean zip nada. Hmm.... yeah I dont know why the technology that Panasonic uses is special or why you bring them up. Their panel is basic n type cell with 19% efficiency that’s just doped in an amorphous layer that will degrade quicker than other materials. SP literally had a 19% panel in like 2013. They do use the 96 cell count like sp lol. LG>Panasonic for sure the neon 2 is much better than Panasonic, there many choices better than Sanyo. And you are right LG is moving on to better technology their new flagship panel the neon R is an exact copy of Sunpower back contact cells just bigger since sp’s patent expired. Why don’t you hate on LG, the LG neon R is just as expensive as sunpower watt for watt. But they did bump their product warranty to 25 years as well. The engine analogy you used is inverted we’re talking production or power, just because 2 cars are 4door sedans it doesnt mean they “produce” the same amount of horse power/energy. And a 5kw doesnt produce the same as another regardless of panels used, especially after 5-10 years. I just used the temp coefficient as one brief example of many factors. Go use virtually any major accredited solar design software and play around with the variables at similar conditions then switch efficiency or moduule type. Here’s a question for you to answer, how come you can have 2 panels with an stc rating of 300 Watts BUT their PTC rating is 10+ Watts different? Is it because the panels performed differently in a different setting? Yes that’s exactly it. Its clear when ppl have an agenda to push and just hate on SP when theres plenty of other panels to undermine.
pretty much they do
that is only if you have a big temp coefficient difference AND a big temperature increase from 25C and even then a relatively modest production difference.
Temp coefficient has negligible impact in cool or breezy locations
Actually efficiency has nothing to do with production. zip, nada.
efficiency only has to do with the size of the PV module not production.
Same for car engines. Efficiency has nothing to do with the power produced. It only has to do with the fuel consumed.
Two engines both that produce 200Hp but one is more efficient, well they both still produce 200Hp, one just uses less fuel....
a 4 door sedan with a 200hp engine will have the same hp as ANY other 4door sedan with a 200hp engine (except transmission & differential inefficiencies in this stretched example)
Maybe IF they can keep costs down, which is doubtful.
but mean while Panasonic and LG are moving forward with each generation.Leave a comment:
I have nothing against Sunpower as a solar producer. Indeed, I've used their cells recently for some specialized panels (panels used for mobile recharging of ebikes) because their efficiency is about the highest you can get in a single crystal silicon cell. I also have a Sunpower system on my house. (Although really that just means the panels; the inverters are rebranded Fronius inverters.)Solar is a great discussion for people to bounce ideas of each other and get advice. In regards to Sunpower I understand there is plenty of people always pitching their brand heavily, but as a knee jerk reaction people develop this anti attitude as well and tear down sunpower soley and never focusing criticism on any other brand. I mean it really invokes anger in people to bring up sunpower.
However, lately their customer support sucks. There are good guys and bad guys in the field of solar system installation; they are one of the bad guys.
And if you do stick around here you will definitely hear lots of criticism of other brands. But you'd have to stick around and read such posts, not come blasting in calling people "kool aid drinkers" "egotistical, proud" "zero credibility" "zero evidence" "you forgot it all." when they disagree with you. Close your mouth and open your ears and you may learn something.Leave a comment:
Thats a very superficial and biased comment, I never called anyone a loser it was actually instigated opposite of what you are supposing. Also Ive posted a few times not 10000 so its not the pot calling the kettle black, your argument is invalid. Further I have no problem with someone posting as much as they want. Solar is a great discussion for people to bounce ideas of each other and get advice. In regards to Sunpower I understand there is plenty of people always pitching their brand heavily, but as a knee jerk reaction people develop this anti attitude as well and tear down sunpower soley and never focusing criticism on any other brand. I mean it really invokes anger in people to bring up sunpower.
pretty much they do
In regards to the original post. If Sp comes out with a 23% panel at mono perc price like they say they are then that would definitely be a game changer. I think they are switching to using 60 cells in a panel like everyone else instead of 96 which means shorter production time, and a bump in efficiency.
Ah yes. Nothing funnier (or more emblematic of our times) than an Internet wannabe who posts in a chat room to call people who post in chat rooms losers.Haha I wouldnt have expected less of a egotistical, proud response based on zero credibility. If you were so sophisticated in the science of solar youd be running a solar company not hanging out in chat rooms. Maybe its because you forgot it all. Youve provided zero evidence for any of your claims just statements of personal experience that doesnt provide any evidence.
Opinions vary. Take what you want. Scrap the rest.
Haha I wouldnt have expected less of a egotistical, proud response based on zero credibility. If you were so sophisticated in the science of solar youd be running a solar company not hanging out in chat rooms. Maybe its because you forgot it all. Youve provided zero evidence for any of your claims just statements of personal experience that doesnt provide any evidence.Leave a comment:
Describing to you what I do with my time and life, and why I do things would be a waste of my time. I forgot more than you'll likely ever know of things you bring up here. Be happy in your hubris and ignorance. Just don't spread your incomplete, unsubstantiated, simplistic, uninformed and ignorant information around to lead others astray. You will be called on it.Leave a comment:
Thanks for the novel of nonsense blessed hoa president that looms on the mountain monitoring everyones production. I have a hard time believing you bought an SP system just to prove a giant conspiracy. If so whats your job everyone would love to be able to throw thousands of dollars away just to prove a point. Just head over to
https://pvwatts.nrel.gov/ and ask them why the technological differences imputed will result in different production output. Why are major players like LG shifting to back contact? Surely its to join the the giant conspiracy of sunpower world domination. No SP kool aid here but it definitely sounds like youve drank the anti sp kool aid and are swimming in it. Lets all just get fed cheap Chinese junk that has been manufactured without quality. Im sure youd love that. Lets all write letters to all the manufacturers wasting millions on r&d improvements. Let them know the hoa god said the current and past technology is sound and a watt is a watt therefore lets use the technology on our calculators on our rooftops. Insert barf.Leave a comment:
