Solaredge 7600 HD Inverter error code???
Hello Butch, I agree with you! No shade on my site. When I was buying my system I asked the technician if it was better to go with the 10kw Solaredge inverter and he said no because as the 7600 inverter would be able to start producing power much sooner than the 10kw. Right now here in CA Ive been clipping since the middle of February. Solar production has been at least 20% higher compared to their estimations. -
That is 10.8kw solar all facing west? Thatis a bit undersized of an inverter for a single azimuth 10.8kw on a 7.6kwHello everyone, after looking online without any luck I figure I post it here and see if anyone knows what it means. On my Solaredge 7600 HD inverter, I found recorded " Error Code: 181
Internal error" listed on the monitoring website every day since March 4th sometimes several recordings on the same day. However, energy production has been good. One thing I'd like to point out is that my inverter has been running what I suspect rather hot. Today, for example, the highest ambient temp was 74 where I leave but the Inverter temperature was 177 degrees with production maxed out at 7.61kwh. I called GogreenSolar since I purchased my system from them, they are having an engineer calling me tomorrow. I've already contacted Solaredge tech support and they claim they do not see any errors on their end but I can see them right on their monitoring website. Any ideas as too what could be happening with my inverter?
System Config:
Solaredge 7600 HD
10,800 watts (Gigawatts 300watts panels x 36)
Panels installed facing West 25 degree angle
how much shade is there?
This temperature reading was taken around 2:00pm today. Outside ambient temperature at the time was 74 degrees.Leave a comment:
System Config:
Solaredge 7600 HD
