My ironclad test if it's real/practical, is "Does the company HQ have commercial power lines running to the property ?"
none so far, they are all fakes/tricks
I'm such a idiot.... for buying into Solar Technologies.
How does this work anyhow ?Leave a comment:
Don't get too excited. The video is a fraud. They did not invent a working machine to do what the video shows.Leave a comment:
pls i need more glue on how to order this new power source.
thanksLeave a comment:
It is the mix of Obtanium and Unobtanium that makes it work.Leave a comment:
I'm impressed with the precise machining of those rotor holes.Leave a comment:
At what time stamp are you seeing them?
My guess is that it's fed from the wires to the fan he plugs in at the beginning.
I don't think the fan ever goes off once he turns it on.
It'd be easy to hide wires in that dirt leading off camera.
An exterior magnetic field is certainly a possibility too - but I think that'd be harder to make work with moving the "generator" around like he did.Leave a comment:
If you look close at the base of the fan you can see a wire running out. It's blurred pretty good but there.
WWWLeave a comment:
You are looking in the wrong place. Lower right portion of the screen they slipped a few times and you could see the cord from the light board into the house.Leave a comment:
What really impresses me is how easy it is to start it spinning by hand. The most common scams require a motor for that purpose.
I am impressed by the way he puts the machine on a cart to show that there are no other wires attached to it, but the three cords leaving under the carpet from the edge of the control board are just a mite suspect.
Similar "generators" I have seen have used motors to "start" the spin but then some type of magnetic field is used to keep it going. Of course the magnetic field is "powered" from an external source which proved the whole system as a hoax.Leave a comment:
I am impressed by the way he puts the machine on a cart to show that there are no other wires attached to it, but the three cords leaving under the carpet from the edge of the control board are just a mite suspect.Leave a comment:
