Uh...... 2017
This is nutz.... go to their "website", and have a good laugh.
Its nothing but cliche's, strung together...
Kick starters and flywheel technology
The thing with Flywheels the tech is as old as the wheel. There are no meaningful improvements left in them. The best wheel is steal on steal rails. There is no way to improve it. Flywheel UPS have been around for 100 years. They were the first UPS systems. Technology antiquated them.Leave a comment:
The tooth fairy and Yeti are more likely to show up - the crowd funding thingies are generally a means to transfer funds from the average Joe to some dingbat with a scheme where he doesn't have to work.
Flywheels from a big company have not happened - from a small shoe string operation it is near impossible.
I still ridicule the idea.
People/outfits claiming breakthroughs in flywheel tech are sort of the bottom feeders of the power production world.Leave a comment:
These clowns are the first? Hardly! What do they have they will cause them to be a success where all others failed? Nothing!
You are so determined to find something "cute" that you are a sucker for this type of thing.Leave a comment:
The issue with flywheels is the amount of space they take up (mostly in height) as compared to the amount of energy it can generate. For small applications they work (I used one on a small computer system to ride through a power dip long enough for a gen set to come on.) But for large applications they are a maintenance headache.
There are also safety issues on how would you stop a "very big" inertia wheel if there is a problem. The "breaking system" is very costly.
So while flywheels are used for short term energy storage IMO they fall way short of a practical way of storing energy from solar to be used at night.
I've got numbers on my daily excess as well as nightime kitchen circuit demand that I'll use to price the system. I also run a server farm that uses .5KWh 7x24 that may be a better initial candidate for the off-grid portion of my overall demand. Maybe it won't be feasible initially in 2016 but price always drops as demand increases and tech improves.
I believe velkess is significant in that they are the first viable home energy storage system that uses flywheel tech. Having a 100% discharge capability with unlimited cycles over a 10 year lifetime along with zero maintenance/charging requirements is significant in my book. I'm still waiting for maximum charge rate characteristics since my system can produce an excess of up to 4 KWh against whole house demand at peak sun.Leave a comment:
The flywheel installations I cited are real as are the reasons Sunking. Your quote of my post above was not something I wrote but was in fact lifted from a Beacon Power promotional paper.Leave a comment:
Now you are just making things up and easy to poke holes through. Flywheels are very inefficient and was very careless to say lower carbon emissions. Flywheel technology has never caught on for this very fact, and never will go much of anywhere. To many inefficient mechanical and electrical conversions, and poor energy density.Leave a comment:
Yup, POCOs use flywheels today. They are suprisingly common. Beacon Power opened a 5MWh, (20 MW over 15 mins) flywheel energy storage plant in Stephentown, New York in 2011. Lower carbon emissions, faster response times and ability to buy power at off-peak hours are among some advantages of using flywheels instead of traditional sources of energy for peaking power plants. A 2MW flywheel storage facility opened in Ontario, Canada in 2014. It uses a spinning steel flywheel on magnetic bearings.
The Velkess bearing is also magnetic in an evacuated enclosure. It was the most difficult engineering challenge faced by the project engineers.
What's truly sad here is that POCOs could easily be driving storage technology to build a smart grid that can inherently store and deliver energy; in fact this is where it needs to be. They could make my valid capacity demand rate (how much using their "battery" to store my excess energy costs me) much more reasonable. They won't though because big energy has become an investment scheme instead of a utility. The end result of this strategy will be the destruction of centralized energy delivery systems and the emergence of micro grids. This isn't good for anybody.
So while flywheels are used for short term energy storage IMO they fall way short of a practical way of storing energy from solar to be used at night.Leave a comment:
I have to go find the article I recently read but they listed all of the types of "energy storage" in the world along with the listed Wattage & percentage.
They listed about a half dozen battery chemistries along with Hydro, Salt and other thermal systems.
While Hydro storage was at the top, surprisingly Flywheel technology was not at the bottom and (from my memory) was listed as having close to 1MW of "storage" capacity in use.
If we could get past the losses due to gravity and friction, flywheel storage might become useful. Maybe possible in space while at low gravity but on earth it is a losing proposition..
What's truly sad here is that POCOs could easily be driving storage technology to build a smart grid that can inherently store and deliver energy; in fact this is where it needs to be. They could make my valid capacity demand rate (how much using their "battery" to store my excess energy costs me) much more reasonable. They won't though because big energy has become an investment scheme instead of a utility. The end result of this strategy will be the destruction of centralized energy delivery systems and the emergence of micro grids. This isn't good for anybody.Leave a comment:
The technology used for these flywheels is revolutionary. That's why I took interest initially. They are supported by a single magnetic bearing at the top, rotate horizontally like a lasso and don't need to be perfectly machined to prevent self destruction at high rpms. A lasso can achieve high rotational velocity because the structure is inherently stable. The same principal is at work here. By eliminating the need for precision machining, you make the system smaller and cheaper. The velkess flywheel is constructed using kevlar rope. Bob got manufacturing on board when he demonstrated the system running at mach velocities.
I'm looking forward to installing a velkess A in 2016. Even at the initial cost of $750/year over its 10 year lifetime, the cost will be about half what WE energy wants to charge annually for "capacity demand" on my 4KW system.Leave a comment:
People have suggested flywheels for a long time; they never seem to survive the real
world. I remember many decades ago a bus that powered up its flywheel at each stop,
never heard any more about it. Recently saw a com center backup flywheel, but then
read it had been removed. Lets see some real products in the real world. Bruce Roe
If we could get past the losses due to gravity and friction, flywheel storage might become useful. Maybe possible in space while at low gravity but on earth it is a losing proposition..Leave a comment:
Both concepts subject to repeated ridicule here. I myself took a massive tongue lashing when I announced info on one particular kickstarter funded initiative after I first joined. (see my first post ever, #97 in this thread and as part of my introduction in this thread).
I still ridicule the idea.Leave a comment:
read it had been removed. Lets see some real products in the real world. Bruce RoeLeave a comment:
