1.2kwh per battery. I assume they can be stacked like S280 inverter (max 14 per string). Max per string can hold 16.8Kwh. It is much more enough for peak hour.
If we charge during the night or morning and use during peak hour (5PM-9PM), it will help a lot.
The weight is 40lb. It can be installed by homeowner ... on multiple different place in the garage (spread the weight across multiple studs.).
I check powerwall (7KW) from Tesla. The weight is 100 kg (220lb). I am not sure how homeowner can install it and how the stud can hold that weight.
For the price point the battery seems expensive around $800/kwh. S280 inverter is around $160, so the battery is around $640. I am not sure if it is worth to buy them.
I got the same issue with Powerwall on the feasibility ... maybe just for fun, not actually profitable solution. $3000 plus inverter cost for 3.3KW inverter. It could go to at least $5,000. Plus professional installation, it will reach to at least $6000 each. Same price comparing to Enphase.
Enphase Battery information
I didn't see anyone post a link to Enphase's page about the product, so here it is:
My quick and relatively uniformed take:
It's roughly $1.2k plus installation for about 1.2kWh of storage, 7300 cycle / 10 year lifetime,
designed for people who are grid-tied but have a crappy feed-in tariff
and have a strong economic incentive to use all their solar themselves
by shifting some of it to nighttime.
Dunno how far 1.2kWh would go for my house, we probably use a lot more than
that after dark. But maybe the average Australian solar user uses less power
than my old house does.Leave a comment:
Is this what you are referring too?Have anyone had more info about enphase battery ? I see it is more usefully vs Tesla power wall.
For Tesla, you must have solar and feed DC power from solar during the day to charge the battery and use it during the night. It is stupid
it is 1-1 convert. If I sell my power during the day to power company and buy back during the night, I got 2X - 3X benefit.
What the best is to buy power during the night and use during the day. Sell everything solar generate during the night. So my value from solar increase 2-3 times
I am not sure if I could control Enphase AC battery to charge during the night and supply during the day or not?
For example with 5KW system, it can generate around 22KWH per day. If I use 12kwh during day time and 20kwh during night time. I virtually can sell 10Kwh to get 20kwh credit for night time to use (Assume 2x credit different in TOU)
Now, if I have 12kwh smart AC battery, I will move all my usage to night time of 32kwh. Charge the 12kwh battery at night and use during day time. Solar power will put back to the grid during day time to get 44kwh credit. So I get 12 extra kWh for any extra things to use.
If I use 10 kWh tesla powerwall, I will end up to pay 10kwh more for my night usage as I get zero credit from Power company
If I use 20 kWh tesla Powerwall, I end up to pay 10kwh day cost which is equal to 20kwh night cost.
I do not see any benefit to have solar edge and tesla power wall for Us where net meter is provided.
What do you guys think?
Dive Brief:
Enphase Energy Inc. says it plans to introduce a novel residential solar storage battery system in Australia and New Zealand this December that would be one of the first capable of storing, monitoring and controlling power use.
The storage system includes integrated software that gives homeowners flexibility in their energy usage and storage.
The system weighs about 55 pounds, and the lithium-iron-phosphate battery stores 1.2 kWh and has 275,550 watts of power output.
I use on average 25 kWhr per day. This battery will give me enough energy for a little over an hour of operation. I do not see the point of it but I might be missing somethingLeave a comment:
Yeap. I guess I miss this. Now, it is time to wait for the two solutions come to live ... I got space ready for enphase battery in my garage and also have extra space in the new sub-panel for them.It has nothing to do with selling, it has to do with offsetting the top tier pricing, using the battery instead of the grid. You are using a Battery to power the Inverter instead of PV. The Solar Edge Inverter will act as a hybrid Inverter with the battery. Don't be surprised if the battery does not control the power that is used.
From your Link:
Avoid Paying Peak Rates
Power companies often charge a higher price for electricity during peak evening hours than overnight when demand is low. Powerwall can store electricity when rates are low and power your home when rates are high.Leave a comment:
It has nothing to do with selling, it has to do with offsetting the top tier pricing, using the battery instead of the grid. You are using a Battery to power the Inverter instead of PV. The Solar Edge Inverter will act as a hybrid Inverter with the battery. Don't be surprised if the battery does not control the power that is used.I got from Tesla. The usage case is to charge battery during the day (peak time) and use during the night. It does not make any sense until POCO not allow you to sell power back to their grid (unlimited battery with 100% efficiency)
http://www.teslamotors.com/powerwall
Since you are not control inverter, there is no way to charge during night time
Plus rule 21 requires you are not put the power you charge on your battery to the grid. Who will control it. Battery itself can not. You need a hardware to connect to your smart meter to control it.
From your Link:
What is I see Enphase total energy idea is the great idea. Especially they conform with rule 21 from POCO. I will wait to see if it can be used to charge from the grid or not, but per ad from Enphase it is .. Smart ACYou can't do it with the Outback and a standard battery pack; the "sell to grid" settings effectively require you to have an external DC source to get the battery voltage high enough to sell. Per the tech support person I talked to at Outback this was partially because they did NOT want to be able to do power arbitrage, due to pressure from utilities.
(BTW it's still doable; you just have to run at a higher battery voltage. I am currently running at 54 volts and it works pretty well at that voltage, although there are problems with charging the battery from the grid due to lower available cell voltages.)
Powerwall is useless according to tesla usage case on their website. Maybe for people who want to use energy from solar day and night without selling/buying any juice to/from POCO. Or dump people who see the slide and feel it is right thing to do
Feel free to see the website about Powerwall
http://www.teslamotors.com/powerwallLeave a comment:
I have a load side, 10 circuit manual transfer switch that I use with my generator for power outages. If I were to try to use batteries it would be with the output of the inverter into the transfer switch ... completely safe and legal.Leave a comment:
You can't do it with the Outback and a standard battery pack; the "sell to grid" settings effectively require you to have an external DC source to get the battery voltage high enough to sell. Per the tech support person I talked to at Outback this was partially because they did NOT want to be able to do power arbitrage, due to pressure from utilities.No clue where you got this from. The concept is the battery recharges from the grid during the night during the lowest Tier pricing or before noon on solar in the low tier depending on your net meter pay rate. The Battery discharges during the evening hours of peak Tier pricing, say 5:00 to 9:00 PM or whatever you have the capacity to support. . . .
By the way anyone with a Grid Zero, Schneider XW or Outback G series hybrid Inverters can already do this by using generator / grid support and the AGS settings.
(BTW it's still doable; you just have to run at a higher battery voltage. I am currently running at 54 volts and it works pretty well at that voltage, although there are problems with charging the battery from the grid due to lower available cell voltages.)Leave a comment:
This is illegal if you connect your battery to the gridMy analysis, granted, not for everyone, was to use a conventional battery charger during the 10 hours at night which up to my baseline (13 kWh summer, 25 kWh winter / day = CA TOU SCE) charges the battery at one cent per kWh (11 cents / kwH - 10 cents / kWh). No cost for panels or charge controller. Was going to simply put a timer on the charger to give it power during those 10 hours to control the cost.
My batteries would be in battery heaven, regularly charged consistently to 100%, and not tormented by cloudless days. However, for a delta of only couple pennies at best per kWh, my time is more valuable.
It will endanger people who work on the grid when it is down...
I got from Tesla. The usage case is to charge battery during the day (peak time) and use during the night. It does not make any sense until POCO not allow you to sell power back to their grid (unlimited battery with 100% efficiency)No clue where you got this from. The concept is the battery recharges from the grid during the night during the lowest Tier pricing or before noon on solar in the low tier depending on your net meter pay rate. The Battery discharges during the evening hours of peak Tier pricing, say 5:00 to 9:00 PM or whatever you have the capacity to support.
Of course you have to have programmable control of the Discharge time and the Recharge time of the battery, without that ability it would be worthless, as per your example. The concept example is to buy ( charge ) at $.10 and store to sell at $.40 with a net difference of $.30 per KWH credit, this makes it win/win.
The ROI is a big question mark. Number of KWH's offset, cost of system, lifespan of system ( Batteries ) and about 10 other things.
My analysis, granted, not for everyone, was to use a conventional battery charger during the 10 hours at night which up to my baseline (13 kWh summer, 25 kWh winter / day = CA TOU SCE) charges the battery at one cent per kWh (11 cents / kwH - 10 cents / kWh). No cost for panels or charge controller. Was going to simply put a timer on the charger to give it power during those 10 hours to control the cost.Well, if Net Metering is available, a battery cost of zero will still not allow an off-grid inverter and CC based storage system to do any better than a GTI under NM. And the GTI will cost less. Panels are a constant to both.
Oh, and any current battery storage system will have an overall efficiency (CC loss, battery loss, inverter loss) well below 90% while a GTI could be 95% or better. The POCO virtual battery is 100% efficient and there are no losses pulling the power back out of that "battery."
There is, however, a battery cost (which has not, IMHO, been reached yet) which will make a storage system profitable when POCO is using a Time Of Use rate system, without the need for any PV at all.
Then you can compare the overall economic return between spending your money on a GTI system or a non-PV storage system.
My batteries would be in battery heaven, regularly charged consistently to 100%, and not tormented by cloudless days. However, for a delta of only couple pennies at best per kWh, my time is more valuable.Leave a comment:
By the way anyone with a Grid Zero, Schneider XW or Outback G series hybrid Inverters can already do this by using generator / grid support and the AGS settings.Leave a comment:
Then you can compare the overall economic return between spending your money on a GTI system or a non-PV storage system.Last edited by inetdog; 10-05-2015, 04:07 AM.Leave a comment:
I just go through enphase dream video. They dream to have smart energy system where home owner sells all energy to power company when the price is high and buy back to store them when the price is low.
It seems very attractive.
Rule 21 does not allow users to send back storage energy to the grid. However, it does not prevent solar energy to send to the grid.
I can't wait to see enphase AC battery, envoy-S and new enlighten software release next year and how flexible enlighten software allow user to control AC battery Via envoy-S.
If they allow AC battery generate a bit higher voltage than enphase (currently enphase will generate a bit higher voltage than the grid), I could see enphase users can maximize their solar and TOU.
Like example I states, first during the day, all power will come from the Enphase battery. All solar power will go to the grid (I am not sure how to prevent battery power drain to the grid ?) Maybe control the max mount of Watt release from battery. Envoy can do it if it get grid usage from smart meter (if plan to do it via envoy-s) and solar production info.
During the night, charge the battery.
So TOU user will get double or even triple credit on All solar generated power
If this work as their dream, I would see the benefit of enphase vs Solaredge.Leave a comment:
Yeah. That is why I wonder how come a lot of people reserved for PowerWall batteries? Did they really do any economic calculation or just want to have for fun or do not know how to do the math?NEM 1 IS buy and sell at same rate....as I stated in my post, however this expires sometime next year and the follow-on program in as yet undefined. In AZ they have petitioned the state to allow buy at wholesale and sell at retail.....IMO it's only a matter of opinion until we get there. In my case I have a 20 year commitment for NEM1 but..........this if course can always change
