Parameters That Affect Solar panels
  • khan2776
    • Jan 2015
    • 5
    Hi
    I am working on hdf files related to solar radiation and there are lot of parameters in that. Some are related to solar panels and some are not. I just want to know if i have selected the right parameters. Following are the parameters:
    EMIS = Surface emissivity
    TS = Surface temperature, ALBEDO = Surface albedo, ALBNIRDF = Diffuse beam NIR surface albedo
    ALBNIRDR = Direct beam NIR surface albedo, ALBVISDF = Diffuse beam VIS-UV surface albedo, ALBVISDR = Direct beam VIS-UV surface albedo
    LWGEM = Emitted longwave at the surface, LWGAB = Absorbed longwave at the surface, LWGABCLR = Absorbed longwave at the surface with no clouds
    LWGABCLRCLN = Absorbed longwave at the surface with no clouds or aerosol, LWGNT = Net downward longwave flux at the surface
    LWGNTCLR = Net downward longwave flux for cloud-free sky, LWGNTCLRCLN = Net downward longwave flux at the surface for clear sky
    LWTUP = Upward longwave flux at top of atmosphere (TOA), LWTUPCLR = Upward longwave flux at TOA assuming clear sky
    LWTUPCLRCLN = Upward longwave flux at TOA assuming clear clean sky, SWTDN = TOA incident shortwave flux
    SWGDN = Surface incident shortwave flux, SWGDNCLR = Surface incident shortwave flux assuming clear sky
    SWGNT = Surface net downward shortwave flux, SWGNTCLR = Surface net downward shortwave flux assuming clear sky
    SWGNTCLN = Surface net downward shortwave flux assuming clean sky
    SWGNTCLRCLN = Surface net downward shortwave flux assuming clear clean sky, SWTNT = TOA net downward shortwave flux
    SWTNTCLR = TOA net downward shortwave flux assuming clear sky, SWTNTCLN = TOA net downward shortwave flux assuming clean sky
    SWTNTCLRCLN = TOA net downward shortwave flux assuming clear clean sky
    TAUHGH = Optical thickness of high clouds, TAULOW = Optical thickness of low clouds, TAUMID = Optical thickness of mid-level clouds
    TAUTOT = Optical thickness of all clouds, CLDHGH = High-level (above 400 hPa) cloud fraction
    CLDLOW = Mid-level (700-400 hPa) cloud fraction
    CLDMID = Low-level (1000-700 hPa) cloud fraction
    CLDTOT = Total cloud fraction
    FOLLOWING ARE THE SELECTED ONES: I think these parameters affect the solar panels.
    Please help me in selecting the right parameters that affect the solar panels.
