Now is the time when the survivors report about the experiment! Both our school projects have ended
with some interesting results, but the concentrators are not fully complete. There are still some things
I'll have to improve and finish, but let's say a good prototype (for both projects) was built.
You can read both reports my students wrote on my webpage:
under the section "Diploma done during 2012". Since we live in the
Italian speaking part of Switzerland, the reports are in Italian, but
one can look at the pics and graphics...
In particular,
parabolic trough concentrator:
parabolic dish concentrato:
videos:
As I said, I will go one working on both projects, maybe with other
students and I will report on this forum.
receiver for parabolic dish solar concentrator
Ok - I will look at that - hadn't seen it!Leave a comment:
Georges did two different versions of his parabolic trough concentrator: the old one (about 2 years ago) with a simple non insulated tube, and more recently, I believe last summer, he did one with a vacuum tube. (see the links in my previous message).Leave a comment:
Some commercial parabolic concentrators do use a vacuum tube rather than like George's - a different thing altogether.Leave a comment:
hard to believe there is no difference in the winter, since vacuum tubes really reduce the heat losses (especially critical in the winter).
Now, maybe you mean the difference between fixed flat panels (with vacuum tubes) vs tracking concentrating troughs (with vacuum tubes) ?
Georges has done interesting tests (concentrator vs flat panels), although both with vacuum tubes and with tracking, so it might not
be relevant to what you had in mind.
for our trough project, yes. It is very similar to http://georgesworkshop.blogspot.ca/2...-20-intro.htmlLeave a comment:
The working fluid we plan to use is Tyfocor LS. It's an antifreeze fluid, the same fluid than the one used in "classical" solar panels with vacuum tubes. It has nice properties (anti-corosion, resistance to heat).
As for the manifold, we'll have to build one made-to-measure, because of the large distance between tubes (around 60 cm). The manifold for solar panels with vacuum tubes have a much shorter distance between the tubes (in the picture attached, the manifold is shown as the bottom figure). As you can see, the copper header will be insulated to reduce heat losses in the manifold.
[ATTACH=CONFIG]2624[/ATTACH]Leave a comment:
What is your working fluid ?
An aluminum block, 24" square, with a grid network of holes and manifolds drilled through it, and the blank ends "plugged" with threaded plugs, will collect and transfer a lot of heat for you. After it's machined, the outer surface is anodized black, to absorb energy better. As long as you keep pumping fluid through it, it's pretty safe, but if you overheat it, you will destroy it.
figure_manifold.jpgLeave a comment:
A parabolic trough concentrator is far safer as regards temperatures.Leave a comment:
An aluminum block, 24" square, with a grid network of holes and manifolds drilled through it, and the blank ends "plugged" with threaded plugs, will collect and transfer a lot of heat for you. After it's machined, the outer surface is anodized black, to absorb energy better. As long as you keep pumping fluid through it, it's pretty safe, but if you overheat it, you will destroy it.Leave a comment:
I am new here and want to see these pic's. name is Logan
Hello,
with my students, we are building a solar tracker using a 180cm parabolic dish
(pretty much like this one: http://www.heliotrack.com/Dish180.html ).
We have the tracking almost under control but my question here is about the
receiver which should be placed at the focus of the parabola. The heat fluid should
go through "spiraling" pipes in the receiver, get heated and then go back to the water
tank in the house.
Does anyone know where to buy such a receiver (even second hand)? if not, can anyone
help us on how to build it (material, dimension, etc).
thanks,
NicLeave a comment:
Yes - a Redrock kit as I rememberLeave a comment:
Nicely put Russ... I'll invest in one of those upmarket things if ever I become a millionaire. Until then I'll settle with our reservoir, despite having to share it with the ducks... hee hee
I have looked at Georges stuff before and to be fair about thirty other websites. George, as you say lays things out quite nicely and his set up is nicely arranged Though for tracking I believe he's using a redRok kit if my eyes don't deceive me.Leave a comment:
On our side, I will post our final document on my webpage. Unfortunately, since we are in an Italian-speaking region, the diploma of my students will be written in Italian, as required by the high school regulation. More later.Leave a comment:
