LED lights
I currently work for a company that does architectural outdoor lighting and street lighting. Right now I'm overseeing their LED projects. As it stands there are a couple of problems when trying to integrate LED's into street lighting.
First of all we are having major overheating issues when trying to retrofit existing street lamps to make them accept LED technology. To manage overheating LED's are under driven to 1 watt per LED since LED's become more efficient with lower drive currents.
solunagreen.com
Mod note - Forget the soluna green link
[/URL]
LED Lights
LED lights
We put LED lights in our recessed cans in the kitchen and dining room. Cree LR-6 lights are what we went with. As far as I have been able to find, they are the only commercially available LED lights with excellent color rendering (CRI> 90). They are expensive though - about $90 per light. There are many discussions about LED lights in the lighting section of the forum. Good luck!Leave a comment:
Actually, there is, it's KELVIN, and you even reference it. The "names of color" also are pretty standardized too. warm white = 2700KYes, what you mean is color temp, but the temp of the light.
Actually, different factories have different stardards for the color temp.
Some just use warm white, day white and cool white to define the color. Also the factory can make the kelvin according to your need. There don't seem to have a Unified stardard.Leave a comment:
Actually the previous poster is apparently a salesman/woman that does not know what they are selling - there are reasonably well defined standards if one wants to search the net a bit.Leave a comment:
Mod note - if you wish to advertise on the site contact user name Jason. You may have your email in your profile but no emails or links in posts.Leave a comment:
I think these are the values: 2,700Leave a comment:
They come in a variety of color temperatures
I believe 5300K is the color of an incandescent lamp.
Here is an explanation
OK, may be you right, thanks. But do you have any suggestion for the standard?Leave a comment:
Wow 5500 degrees Celsius is hot!
I think you mean Kelvin which the color temp of light is measured.Leave a comment:
Is there a standard for LED street light, I mean for temperature equivalent? Usual temp is around 5500 Celsius degrees. I can not find that standard.I have been playing around with LED lighting for years now. I know the first ones were terrible very little and very blue light. I have been testing the newer bulbs using the 5050 LED chips. The light is a nice warm white without too much heat. Pulls 6 watts and has the light output of a 60 watt incandescent. Instant on with no flicker. I have 5 in a ceiling fan testing them out at this moment. Very bright, however the only downside is they don't dim very well.Leave a comment:
led light forum
Maybe this website can help you:www.chylighting.com. It's a professional led light website.Leave a comment:
led light foum
Led light is vey good. IT can save us moe in a long term.Leave a comment:
hi while searching through your query i am across with these two sites. hope this will help you...Hello, does anybody know is there a website/forum about DIY LED lights or information about LED light projects.
See DIY LED projects broken down by difficulty, cost and time with step-by-step building instructions and material lists.
