Doesn't the cellular kit come with the first year of data free?
If so they would have a financial incentive to NOT provide you with a way to increase the amount of data since they're paying the cellular carrier for each extra byte sent.
My guess would be the firmware tells the cellular kit what to do for a refresh rate, and it's possible to change it via a firmware change. But it's not something they want to give an end user.
What's the update interval for SolarEdge monitoring?
I just got access to my monitoring website and I'm setup with the GSM Cellular kit. It seems to be updating every 4 hours. I called SolarEdge to see if they could set it in "High Bandwidth" and they told me that they couldn't because I'm using the Cellular kit. Has anyone been able to update the refresh rate using the Cellular kit any other way? Looking at the Cellular kit manual, it seems that it should be editable from the inverter itself but I cannot find that menu item.Leave a comment:
Ill run an ethernet cable to it to see if it improve anyLeave a comment:
I've found that the zigbees are usually slower than a direct or powerline communicator connection. Direct connection updates every 15 minutes, but you may have to refresh the site.Leave a comment:
You using the browser monitoring portal? From my limited experience the dashboard doesn't auto update. You need to refresh the page and it will pull the most recent data
The other possibility is the common zigbee inverter communication failure. Might not be pulling any dataLeave a comment:
Does anyone know the interval when SolarEdge update its data? my panel rea 3.2kw portal reads 900w. 900 watts would mean like 7:30 this morning. Relatively sunny day
