4.4 kW Solar PV Grid Tie System in San Diego
Howdy J.P.M we are making progress, slowly. We might be ready to do some testing at the end of the week, worst case scenario early next week. I think it might be wise to get a few members involved in some testing, as you are still having issues it might be helpful to get SK and yourself to do a bit of testing before we go live, would that be ok? Cheers. -
The beat goes on...
The PVWatts® service is down and cannot be used to calculate results.
Please go back to the SYSTEM INFO page, and then click RESULTS (it may just be a momentary problem).
If the problem persists, please try later.Leave a comment:
Run PVWatts at both orientations and ratio the two.Leave a comment:
Great info thank you! I do like the idea of it being out of 'sight' I'l need to do some more research on the exact efficiency of a horizontal array vs 10° tilt (which is what I would need anyhow)...Leave a comment:
I corrected some grammar /spelling from the orig. text. (I still can't edit the normal way)"Peak" may not be the most fitting word to use, particularly with a horiz. orientation. When and how to clean a solar panel, like most of solar energy technology, is far from an exact science. One consideration of many, is orientation. It may be likely that in many locations, an array at a high(er) tilt angle (say 45 deg.) may be kept cleaner by wind and rain than a lower (say, 20 deg. to the horiz.) partly due to gravity and a greater washing potential of increased runoff velocity. In the case of (mostly) horizontal panels, rain water or snow melt will tend to stay put as will morning condensate from fog/dew which, as you know, is pretty common around you. During the day, the horizontal panel will act something like an evaporation pond, or a settling pond, leaving all the stuff that came with the moisture as residue. Those who have tilted panels and have noticed the bottom 6" -12" or so of the panels getting dirtier quicker can appreciate that a horiz. panel is that way over a greater portion of the panel, perhaps most or all of it, only worse and perhaps getting that way faster. Next night - same thing, but with no or little runoff from gravity...................Another possible consideration is how to get at a panel in the middle of a horizontal array. Probably a lot of the accumulated stuff can be hosed off if attended to fairly quickly after deposition. In some case, perhaps yours, being near the airport and freeways, the stuff deposited with moisture or by itself falling out of the air (tire dust ?, dumped fuel ?, other ??) may bond or otherwise interact with the panel glass, perhaps affecting any antireflective coating as well, perhaps not, but perhaps more so than tilted panels some SLIGHT mechanical action beyond high velocity spraying may be necessary. If you can't get at the panels effectively, they may not get as clean as desired................. I am not extremely well versed in panel fouling mechanisms, but I'd be surprised if any one is, this being a very imprecise matter..........................FWIW, and for my situation only, after and during a lot of ongoing measurement, I believe my array's performance deteriorates very approximately at a rate of SOMETHING like 1% per week in the absence of any measureable rain, or cleaning. However, my array is at about an 18-19 deg. tilt, and I'm in a fairly benign, semi rural and mostly dust free area.................. related to all this in an anecdotal way perhaps, I spend some time in Borrego Springs. (For those unfamiliar, it's about as hot/dry as Phoenix, but about as quiet and populated as a tomb) I had the opportunity to observe a horizontal array on a residence that had been operating for several months. I did not get to talk to the owners, but the architect for the home, who specified the array and design seemed rather proud of the effort, mostly it seems for the sole reason that it was out of sight on a flat roof hidden by parapets. There was about 1/16" of caked desert over most of the array, apparently left over from the rainy season. Something like half the array was impossible to get at. What I describe is probably a rather extreme case, but it may be a matter of degree and time, rather than an unusual result..................Bottom line, and my opinion ONLY, the probability of a horizontal array needing more frequent cleaning is, IMO only, greater than for a tilted array. Also, IMO only, the probability of long term problems due to excess moisture and accumulated dirt is greater for a horiz. array than for a tilted array.Leave a comment:
"Peak" may not be the most fitting word to use, particularly with a horiz. orientation. When and how to clean a solar panel, like most of solar energy technology, is far from an exact science. One consideration of many, is orientation. It may be likely that in many locations, an array at a high(er) tilt angle (say 45 deg.) may be kept cleaner by wind and rain than a lower (say, 20 deg. to the horiz. partly due to gravity and a greater washing potential of increased runoff velocity. In the case of (mostly) horizontal panels, rain water or snow melt will tend to stay put as will morning condensate from fog/dew which, as you know, is pretty common around you. During the day, the horizontal panel will act something like an evaporation pond, or a settling pond, leaving all the stuff that came with the moisture as residue. Those who have tilted panels and have noticed the bottom 6" -12" or so of the panels getting dirtier quicker can appreciate that a horiz. panel is that way over a greater portion of the panel, perhaps most or all of it, only worse and perhaps getting that way faster. Next night - same thing, but with no or little runoff from gravity...................Another possible consideration is how to get at a panel in the middle of a horizontal array. Probably a lot of the accumulated stuff can be hosed off if attended to fairly quickly after deposition. In some case, perhaps yours, being near the airport and freeways, the stuff deposited with moisture or by itself falling out of the air (tire dust ?, dumped fuel ?, other ??) may bond or otherwise interact with the panel glass, perhaps affecting any antireflective coating as well, perhaps not, but perhaps more so than tilted panels some SLOIGHT mechanical action beyond high velocity spraying may be necessary. If you can't get at the panels effectively, they may not get as clean as desired................. I am not extremely well versed in panel fouling mechanisms, but I'd be surprised if any one is, this being a very imprecise matter..........................FWIW, and for my situation only, after and during a lot of ongoing measurement, I believe my array's performance deteriorates very approximately at a rate of SOMETHING like 1% per week in the absence of any measureable rain. However, my array is at about an 18-19 deg. tilt, and I'm in a fairly benign, semi rural and mostly dust free area.................. related to all this in an anecdotal way perhaps, I spend some time in Borrego Springs. (For those unfamiliar, it's about as hot/dry as Phoenix, but about as quiet and populated as a tomb) I had the opportunity to observe a horizontal array on a residence that had been operating for several months. I did not get to talk to the owners, but the architect for the home, who specified the array and design seemed rather proud of the effort, mostly it seems for the sole reason that it was out of sight on a flat roof hidden by parapets. There was about 1/16" of caked desert over most of the array, apparently left over from the rainy season. Something like half the array was impossible to get at. What I describe is probably a rather extreme case, but it may be a matter of degree and time, rather than an unusual result..................Bottom line, and my opinion ONLY, the probability of a horizontal array needing more frequent cleaning is, IMO only, greater than for a tilted array. Also, IMO only, the probability of long term problems due to excess moisture and accumulated dirt is greater for a horiz. array than for a tilted array.Leave a comment:
I really like the idea of not having them seen from the road! I may have to consider this as my home is on a Mills Act street. I have not applied however and was not planning to due to solar but this may work...Leave a comment:
I'm not sure. I decided not to go with a ballast system after talking with a structural engineer today... Looks like I'm back to the Prosolar SolarWedge Roof System...Leave a comment:
Ya exactly. Also using a non-Duro-Last authorized roofer voids the 20-year warranty which is why I went with this roof in the first place...Leave a comment:
Interesting thread. I was jst curious about the type of roof you have but I couldn't find a pic of one very easily, even on their website, just a long description of it.
Thanks for the links on the tilt mounts or "wedge mounts" as the one company calls them, at $0.12/WDC, I wonder why they price them out like that, I would think they'd be priced out at some combination of panel and size parameters.
What do you reckon is the thinking behind it ?
But in any case $0.12/WDC doesn't sound like so very much WDC is what we are talking about here, right ? And the regular mounts would cost something anyway so just saying.
Anyway it is a whole interesting aspect of the subject, easy to over look for those who have roofs which are favorably oriented etc.
ps. eh, why aren't my smilies working ?
<----- manually placed smiley
Hey Albert,
Jumped up on my roof today to take a few pictures for you. Man it got dirty in a year so that's good to know if I was planning on doing Horizontal mounted panels.
https://goo.gl/photos/1XrJbs5RGEL9DDJn6
Ya they seem cheaper than having Duro-Last come back out and make all kinds of punctures in my roof... Just talked with an structural engineer and he informed me that it was not recommended. My house was built in 1928...Leave a comment:
G'Day Albert,
In Oz we allow about $200 per kilowatt, for angle frame kit and bit of extra labor to install it, so its probably similar or a little bit more in the states, hope thast helps.Leave a comment:
Thank you. Other readers not yet solar equipped may well benefit from your experience.Yes it was a consideration but I had no idea how often they'll need to be cleaned horizontal vs tilted. We get a lot of black crap deposited everywhere....not sure if it's from I5 or from the traffic to/from Lindberg. If you are going to rain, please rain on my roof bit not my parade.
