Is this a good Deal? 6.760 kW DC, SolarWorld/Enphase, Livermore CA for $3.86/watt
Do you mind PM me which installer you went with? TIA
Hello all and thanks for teaching me so much about PV systems! Below is the deal I received. I'm in Livermore CA. Is it a good one?
$3.86/watt DC (before 30% tax credit) Includes financing at 2.99%
Total System Size
6.760 kW DC Power (STC) / 5.738 kW AC Power (CEC)
Estimated Annual Production
10,728 kWh
PV Panel Description
Qty. 26 - SolarWorld Model: SW260 Mono Black
Inverters
Qty. 26 - Enphase Energy Model: M215-60-2LL-S2x
Thanks!Leave a comment:
haha. Good ol' North County. Yes, I guess that's where I live now.Leave a comment:
I believe in another thread he said he lives in RB.Leave a comment:
Chargers old chap, do you mean you live in what we refer to as North County ?
Your inbox will likely receive some messages with recommendations in any case. But not to worry, lots of solar going on here and no need to have a contractor from LA come down.Leave a comment:
Any of those companies also service North San Diego?
Thanks in advance.Leave a comment:
Panels rarely go bad. Out of the thousands I've put in, I've had one shatter it's glass for no apparent reason and one get hit by a 2x12. I've had dozens of optimizers go bad. If you have shading issues maybe its worth the risk to use optimizers, if not - I won't do it anymore.Leave a comment:
I understand that. The inverter I had is SMA TL6000-US-12 with single MPPT, so the whole arrays drop..... Even with 2 MPPT, to track down the bad panel still PIA.
I can only base on instantaneous output of season to determine if any error....Leave a comment:
Say you have 24 panels in two strings feeding into each input of the inverter
One panel goes bad
There will be a big difference in production between the inputs.Leave a comment:
My theory is that central inverter circuits have a bit better conversion efficiency due to economy of scale which overcomes the losses due to mis-matched panels and dynamic effects.Leave a comment:
In some jurisdictions we are forced to use either emphase or solar edge for the rapid shut down features.
I agree that with no shading issues a single string inverter is simpler and better long term.
Those who don't need it for shading seem to have a great need for panel level monitoring. With the dual mppt inputs of modern inverters a simple comparison of the two inputs is more than sufficient to detect problems.
Very unlikely that a two panels on two strings would go out at the same time.Leave a comment:
I got a Xantrex inverter in 2008, still truckin'.
What do you suppose the difference is -- less clipping?Leave a comment:
I put in one of the first SolarEdge (distributed inverter) systems in 2011, because I saw the beauty of the architecture and expected to see better performance. Due to circumstances of being a dealer, I already had a Xantrex system on my house, so split the array and put 12 panels on a 3.3kW SolarEdge and left half on the Xantrex. After watching the two systems compete for a few years now, I can report that the Xantrex old, central inverter consistently beats out the SolarEdge. Early morning - theSolarEdge gets a better start but the Xantrex goes ahead during primetime and doesn't lose it in late afternoon. I haven't tried swapping the panels around to fully test the theory, but I don't believe the hype about individual optimization being better any more (unless in shady situations of course)Leave a comment:
