SolarEdge POWER Accuracy? 11,900 AC Watts from 12,000 DC array
Understood, posted to show that there can be even more surprising output numbers than in the OP. I think my inverter was clipping too, wondering how high the spikes would be with no clipping. -
That's mostly because instantaneous solar radiation peaked at 1,100 to over 1,200 W/m^2 several times today. Nothing unusual for cloudy/pt. cloudy skies. Today's total around here is likely to be about 75% of a clear day's output for this time of year.Leave a comment:
I saw up to half-minute bursts of 10200 AC watts today from a 9kW DC system on a 10kW inverter.Leave a comment:
The last few days, the pyranometer next to my array has reported and recorded several periods from 1 min. up to 20 min. when the global horizontal irradiance reached over 1,100 W/m^2, with several of those 1 min. interval reading in succession over 1,200 W/m^2. The highest 1 min. irradiance was 1,267 W/m^2, 30 successive min. at 11:42 to 11:45 P.D.T., 05/18/2015. All high readings were only momentary and are due to reflections and forward scattering of sunlight by clouds. For the last 16 months, the highest clear sky P.O.A irradiance I've calc'd is about 1,030 W/m^2. There may be some ground reflected radiation component in there.Leave a comment:
Haha, you want to see something really funky? A few days ago I saw 5.32KW AC from my 4.8KW system.
[ATTACH]6748[/ATTACH]
I'm sure it's a combination of cloud edge effect + SE SW glitch. It's no way physically it can happen in any sustainable fashion. So I wouldn't pay too much attention to instantaneous measurements, especially in a partially cloudy day.Leave a comment:
Yeah clouds rolling by etc, it was instantaneous, spike, barely caught evidence of it5600.jpgLeave a comment:
On SE web portal (see signature) the "Current Power" changes every few minutes or so. I'm not sure how it is calculated, but it's very erratic in partially cloudy days as the result of edge effects (light reflect and refract off cloud edges, and sometime focuses large amount of light onto a small area, like a magnifying glass) and cool temperature. So maybe for a few seconds or minutes it did reach 5.32KW, but definitely not over a long period of time.
That is why there is research using concentrated or magnified solar pv panels so more photons can be captured to create a panel with a higher % yield.Leave a comment:
On SE web portal (see signature) the "Current Power" changes every few minutes or so. I'm not sure how it is calculated, but it's very erratic in partially cloudy days as the result of edge effects (light reflect and refract off cloud edges, and sometime focuses large amount of light onto a small area, like a magnifying glass) and cool temperature. So maybe for a few seconds or minutes it did reach 5.32KW, but definitely not over a long period of time.Leave a comment:
It's like using a meter to measure your kW load where you see a "peak" kW when the AC unit comes on but the actual continuous load is much smaller after the initial start.Leave a comment:
sunday was funky, at one point my 5.2kw system was reading 5600 !!!Leave a comment:
