DIY 5.1 KW System in Bay Area
My understanding from talking with people in PG&E area is that if you earn $15 of credits during peak you can use $15 of energy (peak or non-peak).If I use approx 25KwH per day, 18 of which is in off-peak; I produce 20KwH during the day, 15 in peak, how does PG&E calculate net metering? Is it purely consumed-produced KwH (on a yearly basis) or there is a complex formula here? or is it based on $/W for produced & $/W consumed used in the calculation?
I am trying to understand how a smaller system with TOU will offset the usage.
SO best situation is if you produce completely during peak and consume completely during non-peak.
You're estimating that your consumption is 18kwh nonpeak and 7kwh peak.
And production is 5kwh nonpeak and 15kwh peak.
Without looking at the $/kwh to confirm, I'd beleive that the 8kwh (beyond consumpiton) during peak will more than pay for the 13kwh nonpeak.
One thing to note - if you have the above scenario all year long, and you have extra $ of credit, AND have generated fewer kwh than consumed, then at that 1 year mark your credits are zeroed out. (with no check cut to you)
ONLY if you produce more kwh than you consume will you potentially get a check from PG&E. BUT that check is going to be ~$.04/kwh for your excess production. And $.04/kwh is not a lot - very likely less than cost_to_install/total_energy_generated. SO often your best choice is to size it so that you're definitely smaller than total # of kwh consumed - but that you'll generate enough (or almost enough) dollars in credits to pay for your use.
If you size it a little bigger and you have credits that get zeroed out at your yearly anniversary, you could consider it a "gift" to PG&E - that's one of my friends attitudes... He thinks they've got enough problems, so he's OK with giving them that little "gift" since he's getting to use their grid for cheap.Leave a comment:
Question on Time of Use
I am trying to understand how a smaller system with TOU will offset the usage.Leave a comment:
Firecode in my city
You are correct. I checked with our FD in the city & they gave me a nice hand out. Edge/Eve/Ridges - should leave 3 ft, which I have planned to leave.Leave a comment:
Also check which edition of the fire safety code you have to comply with, you likely can't go within 3' of the edge or ridge line with panels.Leave a comment:
I'm a New England gal, not too familiar with the concrete shingle flashings for conduit. My gut says that the SolarDeck won't work with them, you'd be better off with a Midnite MNPV6-DISCO AC MICRO http://www.midnitesolar.com/productP...tOrder=4&act=p
And yes, this would wire them in parallel.Leave a comment:
Hi Basslakerider, I downloaded google sketchup last week & have been playing around with it. It may take a while to do the design/drawing myself. I checked couple of online design services.. i can email you my thoughts since I can't mention names in the forum.I'm doing the same, no suggestions from anyone here yet on design services, I just googled solar design services and not sure who I will use yet. But get your panels inverters, etc. stuff at Renvu in Mountain View, several good recs here, and prices there are very good for DIYers.
First I have to firm up my decision on 'what panels' to get before jumping into design. I hope to decide by end of this month.. my day job is keeping me busy during weekdays.Leave a comment:
My roof type
OK. My roof is a two story, concrete tile roof. I have been up on my roof several times, but not to the edges much. I called couple of roofers to just quote me on setting up just the mounts (QV tile hook mounts with flashing). One of them quoted a reasonable amount for a day's effort (give or take). I might go with that idea. Once the roof mounts are in, plus I will have a few 'safety hooks' setup near the ridges, I can use safety harness & feel comfortable in mounting my panels & doing the wiring. That is my plan so far.
If it were shingles, I could do it myself since I have volunteered several solar installations through Grid Alternatives in Bay Area. I plan to go for one or more installations before I do mine!Leave a comment:
Design and drawings
Thanks sdold. Yes I have been checking them out for the panels/inverters, etc. I agree that design & drawings take time (especially for someone who does not use sketchup or other autocad type tools regularly). I am going to give it a shot & see how difficult it is. I have an approved plan from my neighbor who installed Supower systems using solarcity & I can just follow the same set of sheets.I sent you a PM a couple of weeks ago recommending Renvu, a friend and I both had a good experience dealing with them. The customer service is good and they were happy to take back things that that I turned out not to need. You can also drive over there and pick up will-call items.
I did my own calcs and drawings for the permit, $500 sounds like a fair price, it was a lot of work!
I also checked with 3 different designers (talked to them & asked for a quote) - ACO solar quoted $1000 for design services, renvu for $550 & another designer quoted 1200. One of them asked me whether I need PE stamp (not sure if that is required?). If required, I think they will add extra $$. the 1200 quote included PE stamp.
When I compared renvu prices to aco solar, aco came out a bit cheaper but I don't have any reference/recommendations on them. At least a few forum members have had very good experience with moutainview supplier!
I will keep posting my thoughts, plans, etc. as I work through the details. Appreciate everyone's help in guiding me!Leave a comment:
I did my own calcs and drawings for the permit, $500 sounds like a fair price, it was a lot of work!Leave a comment:
What kind of roof shingles or tiles do you have?Leave a comment:
I'm doing the same, no suggestions from anyone here yet on design services, I just googled solar design services and not sure who I will use yet. But get your panels inverters, etc. stuff at Renvu in Mountain View, several good recs here, and prices there are very good for DIYers.All,
I am in the process of planning & designing my solar system for my home. Based on my usage over the last 3 plus years, I have decided to go with 20 panel system (5.1 KW if I use 255W panels) which will produce approximately 7500KwH per year (my usage is around 7600 to 7700KwH). Planning to install it myself, but may get the design/permit service done by someone (online I saw some for $300 to $500). Have a licensed electrician for connection/inspection part.
My system will be: 20 255W panels (thinking of renesola) + M215 enphase. Will have 3 circuits (roof 1, 2, 3 areas) with 8+10+2 panels. I have to learn a few more details before going for the design. I plan to run the conduit in the attic.
Have couple of questions regarding the wiring of the three circuits.
1. The roof 1 area (8 panels) is about 15 to 20 feet away from roof 2 area (10 panels) & roof 2 area (2 panels) is about 6 or 8 feet away. Should I bring the three circuits to the attic separately & then use a AC combiner box in the attic? This will literally make no conduit visible on the roof. I can put the three 'junction boxes' just under the panel/run the conduit into the attic. OR should I run some conduit on the roof (from roof 1 area to roof 2 area, then roof 2 to roof 3 area & then put a combiner near roof 3 area/then go to the attic)? I have hard time deciding on this. OR will the design/permit service provide diagrams that will show the details? (I will check with them but I want to know/learn myself first!)
2. I assume the three circuits will be connected in parallel? (240V AC coming out of each circuit). is that correct. Using a SOLADeck AC/DC combiner box for 2 or 3 branches.
Suggestions on places to buy the panels/inverters will be great.
Thanks for your suggestions.Leave a comment:
Time of Use plan
Thanks. I earlier analyzed & also had couple of installers give me quote based on my usage. I am already on TOU (E6). My usage is roughly 80% off peak & 20% part-peak/peak. Based on that the recommendation from installers were 4.8K or 4.5K system (covers close to 85% of my usage). So, I thought going with 5K system will cover 100% of my cost.Leave a comment:
You might want to analyze if a time of use plan works for you. If you are not at home during peak demand hours, you can probably get by with a smaller system.Leave a comment:
All,
