I just had a 8KW system installed by an installer. Now I don't trust them...
When you have to install your envoy near the solar subpanel and if there is no ethernet or wifi (if you use a client bridge like TP-LINK TL-WR702N) access there, then one way is to use ethernet over powerline AND THAT IS HOW PEOPLE (INSTALLER?) GET CONFUSED mixing that idea with the powerline communication between the envoy and the micro inverters. A powerline can handle both "ethernet over powerline" and the 144Khz communication between envoy and micro-inverters but they are TWO different issues. -
Really, why would that matter? I have a Sunpower com. system, two eGauge units and a PC all on separate sets of PL modules. Not a spec of trouble. Powerline is crude and rude but gets the job done when homes don't have the necessary Ethernet jacks in the right places. Is this something specific with the PL modules supplied by Enphase? I use Netgear PLC units.
They also said Envoy does not like to travel long distances, especially for ground mounts located far away.Leave a comment:
Yeap, another way is to cut that 3/4" pipe and insert a 1 gang box. There are 4 wires inside the pipe - black red white and ground for 240V. Wire the black, white and ground for 120V for the envoy. It will not be to the code but it will work (and that is not easily reversable and might "void" the warranty should the installer come back, or get me in trouble if the city inspector comes back.)
I just bought qty ten torroids. I will put one on the defending circuit first. Hopefully there is just one defending circuit.Leave a comment:
Yeah, that's what I was saying- you don't need a separate breaker for something drawing mAs...Leave a comment:
Yes, I figured that out after reading the troubleshooting guide. The problem is the subpanel has no slot for more breaker. Now I could only isolate the interfering circuit, if I can find it, by a ferrite toroid or just put one on each other circuit. That was the installer's job, wasn't it.
put the ferrite isolator between that point and the breaker?
As for eliminating the source of interference caused by your light fixtures and your house wiring, I do not feel comfortable putting the entire responsibility for correcting that on your installer. Working with you to identify the problem, sure, but not fixing everything that is wrong in your house wiring as a zero cost part of doing the installation.
Getting power line communication to work properly is something of an art.Leave a comment:
Overall, there are many things one can try to get comms up&running. I get the feeling like if you don't want to DIY, good luck then. At least try to eliminate the possibility that the PLC units being supplied with Enphase could be crap. Easy way to find out is to piggy-back their junk on top of a set of Netgears and see what that gets you. I do that with Actiontec units (major junk) and they work fine no matter where they are placed.Leave a comment:
Really, why would that matter? I have a Sunpower com. system, two eGauge units and a PC all on separate sets of PL modules. Not a spec of trouble. Powerline is crude and rude but gets the job done when homes don't have the necessary Ethernet jacks in the right places. Is this something specific with the PL modules supplied by Enphase? I use Netgear PLC units.Leave a comment:
Do you have another energy monitoring system installed? Like a TED system? Or some other PLC system? Envoy does not like to play well with these other guys.Leave a comment:
It is when it's engineered and installed correctly. Mine has been working perfectly since I took care of the problem, the way I had hoped you would be able to do. Good luck with your system.Leave a comment:
Edit: Wait a sec, where are seeing per-inverter reporting on a public site? The only place I see that is in Enlighten Manager.Leave a comment:
Oh, check out amazon reviews. Everyone is complaining how sporadically envoy works.Leave a comment:
BTW, I go on Enphase's public sites often and notice jobs with one or more micros not talking. Is that what you can expect with Enphase?Leave a comment:
A mechanic helps you to put a new engine in your car. When he says he is done, he shows you the new engine working but the speedometer is not working. He insists there is nothing he can do and wants full payment. Do you pay? Then you later read up and learn that it might be just a cable loose, do you fix it yourself or keep calling him to ask him to fix it (while you are looking right at the loose cable)? Or fix it yourself and dispute the charge and deduct the money for the time you spent doing his job and possible a value for warranty?Leave a comment:
