6Kw going in soon in Aliso Viejo
Using std. PVWatts defaults, my output was 1.3 % lower this April (866 kWh) than the PVWatts estimate. Last April it was about 5% higher (922 kWh) than PVWatts estimated (877 kWh).
This April's horizontal irradiance was about 7.2% less than last April's.
This April's output was about 6.5% % lower than last April's.
Ave. temps for the month on my roof were 63.3 deg. F. and 63.2 deg. F., 2014/2015 for all times averaged in 1 min. increments.
The ave. wind speed was higher this April (3.1 MPH) vs. last April (1.65 MPH) which may be why this year's output decline was not as large as this year's irradiance decrease - the array probably ran cooler due to higher wind velocity.
Add: Potential Sunpower owners take note - Bob's output for April was pretty much in line with what I've been saying for some time now: That in spite of a diff. in location and orientation, his non Sunpower array which is 1.24 times my Sunpower array, consistently manages to produce about 1.25 times or so more output, or, about equal output per installed kW. This is also in spite of my probably higher ambient temps. and likely clearer morning weather and a different TMY weather location. Not a smoking gun, but consistently more than anecdotal data that most decent systems produce about the same output - Sunpower and most every else's, making Sunpower grossly overpriced for most applications.Leave a comment:
Suggest keeping an eye/record on outside ambient temps as well. If it's hot tomorrow, the A/C and therefore elec. usage will probably lag the outside temp. changes by a few hrs. or so. If not, you may well have a leaky house.Leave a comment:
As a "TEST".... I'll put both thermostats at 72 degrees tomorrow, and keep it cool for a 24 hour period, as see what the usage is....Leave a comment:
That's pretty good. Your TOU plan only has a 6 hour peak time?
It was in the mid 90s here the past few days and my net metering isn't turned on yet
Didn't need it during the day until about 4PM, kicked in at 79 degrees, then dinner activity. Late night spike is car charging and a last a/c run for a little bit.
4_29 Usage.jpgLeave a comment:
I was home on Tues during the day... set the thermostat to 72 when I got home at noon.
Finished the day, slightly over.
The spike in the evening was my kids, baking chocolate croissants.
Yummy!!!
This is a typical day, without running the A/C
solar60.JPGLeave a comment:
Bob, you run the A/C during the past few days?
Wonder how it affects your numbers, especially if you run it during the peak times in your TOU plan.Leave a comment:
He has 24 panels, but somehow the design graph only shows 23 panels.... I told him to call the installer later on. they pairing his LG280W with M215... I guess his W270 should be ok.Leave a comment:
Cool! Glad it all worked out....Leave a comment:
Hi Bob,
My friend's system is up and running 24 X LG280W
Thanks
