Ay! There's definitely a lot of things to consider.
I did see some numbers on another site from someone in Phoenix who was on the noon-7pm TOU and you're completely right, they had a bunch of excess kWh on-peak and no enough off-peak, but with off-peak being 1/4 of the cost of on-peak power, it still worked out better in their opinion. Then someone else chimed in and said they are on the standard rate plan and they found that it worked best for them.
I guess it goes without saying that it will depend from person to person. We are currently on the noon-7pm TOU already and we use quite a bit on-peak since we are home all day and keep the A/C at 77º even during the day, and have a 5 ton and a 1.5 ton A/C system.
Is there really a way to accurately calculate? I mean I know how much we use on-peak vs off-peak, but how do you figure how much the system will produce between the different hours? How big is your system Ian and which way do the panels face? What is your production like if you don't mind sharing?
Looking to go solar...everything looking good, am I missing something?
Depends on who you talk to. If the panels have Bosh name on them, I think they're discontinued. Ask another CA poster w/the handle "Silversaver". He got a great deal on some discontinued Bosch - <$3.00/W and his performance seems up to snuff. I've got a Rebadged PVI 5000. It's only been in service about 6-7 months and seems OK. Runs quiet as a church mouse, but clips at 5035 W, which is mostly OK under clear skies around here, as max. array clear sky output will be ~~ 4,800 W, +/- some. The clipping occurs when transient irradiance behavior under pt. cloudy skies cause reflections from clouds and enhances irradiance by about 10 - 20% momentarily and intermittently. Based on my experience, On a 10.7 kW sys., I wouldn't go smaller than 2 X 5kW Power One's.Leave a comment:
I would echo JPM's comments about how to figure system size. You have APS and there are some kinks in trying to figure out the best size. There are two rate structures available for you: standard plan and time of use plan. I am on time of use with APS and I have found that even though my system is sized for about 2/3 of usage, the way the rate structure works, I wind up with hundreds of kWh excess peak credits at the end of the year for which APS pays you peanuts at the annual trueup. So, in effect, they are wasted. But, I'd be even worse off with the standard rate on overall annual savings. So even if I increased the size of my system, my bang for the buck would be worse until the point where I offset nearly all of my electric usage at which point it would make sense to switch to the standard rate plan. So, the best bang for the buck seems to be something around 50-60% of your usage on the T.O.U. plan and something closer to 100% usage on the standard plan. Your bang for the buck will also be impacted by non-south exposure although east may work in your favor on the noon-7PM T.O.U. plan.
Confused yet?Leave a comment:
Thanks Ian. I knew about the tax credit thing, it shouldn't be a problem as we are self employed and currently send in quarterly estimated taxes so we'll just stop sending those and put that money aside to pay the 1st year loan.
I read about the property tax on leasing as well which is a pretty big slap on lessees, I can't believe they can actually apply it to people who are already leasing too, you'd think they would be grandfathered in and new lesses would be subject to it.
From what I understand on the system size, the roof size/shape will determine that more than anything right? I mean budget too of course but if you don't have the space, it doesn't matter if you have the budget.
We've been in the house for 10 months and I did a sort of self analysis of our usage and what I estimate we'll save (based on the Solar City guaranteed output). It will pretty much be a wash at this point, maybe a savings of $100-$200 per year but once it's paid off, then we'll be savings around $2400 per year.
I try to keep my mouth shut about AZ particulars and I don't know much about AZ pricing, but $3.00/W seems quite low. Whose panels ?Leave a comment:
Hey guys, new member here and I'm interested in adding solar power to our home in Phoenix, AZ. I've considered it for a while but just in the last few days got serious and actually started getting some prices/specs/etc.
Originally I was thinking a solar lease which I got a quote for $175/month for a 10kW system from Solar City. Then in my research, I found that for the same amount, I could actually finance a system over 12 years which I would own and it seems like a much much better way to go unless I'm missing something?
I'm going by the data from another local guy but he got a 10.71kW system for a price of $32,000 minus $9,600 Fed rebate minus $1,000 State rebate. The setup was two loans, one same-as-cash 1 year loan for $10,600 (the rebate amounts) and the second for $21,400 for 12 years at 2.99% which is $177/month.
Based on those figures, it would make zero sense to go with a lease at the same monthly payment and you never own the system, plus you're paying that amount for 20 years. With the finance route, after 12 years it's paid off and then your monthly electricity payments really drop.
So am I missing something? Something I didn't consider? I know that with a lease, they maintain the system and guarantee a certain output but from what others have told me, there really isn't much maintenance anyway plus these systems normally come with a 25 year panel warranty and 10 year inverter warranty.
Thanks for the help and any feedback is appreciated.
What you really have to figure out is the size of the system that will give you the most bang for the buck. That depends on who your utility is, its rate structures and your usage patterns. It helps to do some sort of energy audit and implement appropriate conservation measures first before going ahead with solar.Leave a comment:
I've talked to 7 companies so far, 6 of them local and have appointments already setup with 4 of them, including one later today so I'll get some real specs on sizing etc. The 10kW system was based on Solar City looking at Google maps and using their software to do a quick setup/layout.
This is what they came up with. The majority of the panels face south and there are additional ones facing east.
I'm hoping we can do something like this which I think would be more beneficial, but not sure if there is the space because our city required a 3' setback from tops and sides (but not from gutter).
Nope you aren't missing anything. The lease deals tend have a fairly high finance charges built-in.
I don't know the AZ market but in CA $3.00/wDC is a good price. If you trust the installer and the system is designed and sized right then you have a what appears to me to be a much better solution than leasing.Leave a comment:
