CSI EPBB Calculator Question
The estimate is based on CSI calculator, which not much different from PVWatt when I plug in the number. I'm pro oversizing, so I wish I can go larger if SCE allows me to. I know I will be using more electricity in the feature. I actually ask for larger system but vendor says no. I have been conserved the last 2 years, and it make no sense to me to live in the same style even with solar installed.
System : 6.63 kW, Az. 245 deg Tilt 23 degLeave a comment:
To your question of my Jan. production:
1.) Production as reported by the monitor was 629.95 kWhrs, 01/01 - 01/31 inclusive.
2.) If Jan. weather was identical to a typical TMY 3 Jan. for Miramar MCAS and slightly irradiance adjusted for zip 92026, using my methods, my production would have been 610 kWhrs. Using SAM and TMY 3 data for Miramar MCAS, the output estimate was 620 kWhrs. for Jan. Thus, the data would suggest Jan. was about 1 to 2% or so better than a Jan. that had TMY 3 weather and irradiance.
3.) My weather station horiz. irradiance for Jan. was about 102,647 Watts/m^2 w/ some shading after about 1430-1500 hrs. or so. I'm guessing I might add 1-2 % to that total to account for the afternoon shade. TMY 3 is about 102,881 W/m^2.
4.) My SWAG for Jan. at my house, based on the above is that it was a pretty typical Jan., maybe a few % more sunshine in spite of what I, and most others thought was a pretty sunny month. I try to be careful about data gathering and interpretation. This data seems to make sense and hold together even I it does seem to go against what I think happened last month. We'll see what Feb. brings.
System : 5.232 kW, Az. 195 deg., Tilt 18.5 deg., lat. 33.21 N, long. 117.096 W., El. 1380 ft. above M.S.L.
Without knowing any more about your system, I guess that your larger size and perhaps less ideal azimuths than my sys. would tend to make our outputs somewhat similar, which your 633 kWhr. output might suggest.
It may be interesting to note that your estimate of 535 kWhrs. is about 15 % less than what you achieved in what may have been, based on the above an only slightly better than normal month. Did that 535 kWhr. figure come from the vendor or the CSI incentive calculator or PV Watts or somewhere else ? While not a smoking gun for overselling by underestimating, it looks like it might fit the pattern.
System : 6.63 kW, Az. 245 deg Tilt 23 degAttached FilesLeave a comment:
I should have been more specific. That system's performance is something like 10-15 % greater than the vendor's data would have predicted for the same actual weather data we experienced for Dec. & Jan. The vendor used that probably overly conservative .77 from the CSI incentive calculator (which BTW, as Russ alluded to is not a design/sizing tool). I'd suggest .82-.85 would have been a more appropriate using PV Watts.
What happened here is another example and pretty typical of how vendors can and all to often do use customers ignorance to sell more product. Customers, in their ignorance are usually happy because their system is producing more than they were told it would, thinking they got a deal, but are clueless that they may have been misled by an overly conservative estimate into buying more and thus paying more than is actually necessary for what they were told they would need. This can often result in oversized systems that are almost always less cost effective, which is fine if that's the customer's choice. Usually however, they don't know a thing and get screwed. Give the customer straight information, don't take advantage of their ignorance and let them make their choice on honest, more realistic information. The possible deception as I describe is what I have a lot of trouble with. I apologize to any ethical vendors who may take exception to my opinion(s).
Caveat Emptor.
It may be interesting to note that your estimate of 535 kWhrs. is about 15 % less than what you achieved in what may have been, based on the above an only slightly better than normal month. Did that 535 kWhr. figure come from the vendor or the CSI incentive calculator or PV Watts or somewhere else ? While not a smoking gun for overselling by underestimating, it looks like it might fit the pattern.Leave a comment:
Caveat Emptor.Leave a comment:
My neighbor would love to heard that. In general, I think most of new install seems to getting those "surplus" mainly due to the nice weather we got here. My Jan 2014 expected production were 535kWh and I'm getiing 633.47kWh. What's your?Leave a comment:
I'm definitely glad I have found this forum, and I don't think many people here getting what I got for $2.84 per Watt DC before incentive. I have referral the same solar company to my neighbor and he is about to sign a 8.5kW system install on his NE 70 roof. and SE160 roof. Majority of panels will be on NE facing roof. We all know that is not the best place for them, but he doesn't want the solar panels to be seen in front of the house. Estimate 11,000kWh for a 8.5kW system seem to be little, but that's what he prefered.Leave a comment:
$43K - nice. Capitalism at work. Know this: The salesperson's job is to leave your home with an order for goods and services - not help you because you're a nice person, not reduce your electric bill, not save the planet - all nice sentiments that perhaps will come to pass, but in the end coincidental to the mission - sell equipment as profitably as possible. That's not evil - it's just business. Caveat Emptor. Several quotes help. Bet your glad you found this forum , huh ? You must have missed my epistle some months back when/where I think I described my request for quote/bid selection process. In fairness to sales folks in general, most don't have the time for what I very briefly described, and right now probably don't have time to bend over and scratch. All the more reason to get and be informed before you get (several) quotes - part of my rant about trying to know the answers before you ask the questions.Leave a comment:
The rant.
JPM please can you post a link?
Thanks.Leave a comment:
Thanks for the feedback. I agree with you. In reality, none of the sales rep will follow up that method. Why? Since I join the forum until now, I haven't seen single post about anyone asking for best installer without asking for price first. If your price isn’t good, you are not even on the list. I still remember the best proposal I received were from an installer offering me 24 X LG280 with Enphase M250 micro inverters. The presentation was nice and detail. When I look at the price, I just can't believe it. Yes, I read the number twice. $42,985 I did call the Sales Rep asking if he had made the mistake, the answer is No. I have forgotten which company was it, but I still remember the price.Leave a comment:
