Hi Russ,
Base on your experience, how much higher production will a SunPower yield than other makes?
CSI EPBB Calculator Question
The Power Temp Coef (Pmpp) - 0.30% is pretty low compare with other makes @ 0.4% to 0.45%. SunPower has super 25 years warranty and others only 10 years.
Since SunPower offering 25 years, so you will get your panels covered since no way you can match SunPower panels with other makes if panels were bad. On the other hand, most of the 60 or 72 cell panels can be replace with other makes if needed.Leave a comment:
Good point that you guys make, I hadn't thought about the 30% thing expiring.
I think if the expansion is imminent within a year or two at the most, then oversizing may make sense if your POCO allows oversizing. If much longer, it make not make too much sense because the parts may become cheaper in a few years. But then again, we also don't know if the 30% tax credit incentive will be renewed after 2016 or not, which is only 2 years away now. So that also needs to be taken into consideration.
Regarding oversizing now to save on repeat cost of permits and fees, Naptown has shared with us some good info about the cost, and it looks like the structural study and drawing cost is the lion share of it ($1200-$1500) out of $1700 total. But I really wonder if a structural study is required in all cases or not. I really doubt that one was done for my installation because I didn't see any evidence of it, while I see all evidence of all other kinds of paperwork. Maybe there's some easy criteria that determines whether a structural study is required or not, and in most cases, it's not for a normal home roof top.Leave a comment:
Really true in most cases. You should look for (these datas are from Sunpower panels) -
1) Power Tolerance +5/–0% +5/–0% - many will have a negative tolerance - plan on the output being closer to the minimum than the max.
2) Power Temp Coef. (Pmpp) –0.30% / oC - some have a significantly higher loss of production when hot and your roof will be hot
3) UL listed or equivalent
4) Warranty terms and length - is a 3rd party guaranteeing the warranty in the event the manufacturer goes under?
Others can add as they wish.
[QUOTE=silversaver;98143After months of reseach, I don't think any panel were superior than others, unless limited roof spacing, [/QUOTE]
RussLeave a comment:
Thanks for that, Silver. My thought process is similar to yours -- eg. possibly an electric car in the future. The tenant in my rear unit recently bought a Volt which he can charge at work for free. My mom's house is around 2700sf and with 4BR 3BA and is suitable for a family. Who knows who might live there in the future.
"Oversizing" seems to be a subject about which people are passionate on this site, with most people dead set against it.
Most of us are here to learn and I suppose a good healthy discussion will promote that.
Those are great results.
The installers I've contacted so far seem to have their favorite panels, ranging from 245 to 270W per panel. I'm not sure how the distribution works -- it seems like some installers are more flexible than others on the panels. What was your experience on that? Did they offer you the Bosch or did you find them yourself?
In any case, you really made out with that crazy low price.
I had an early flurry of activity but have been super busy the last several days and have just let things rest for the most part.
2014 is still new, keep shopping among good installers. I have seen SMX panels + SMA @ $3.2 per WattsLeave a comment:
I had an early flurry of activity but have been super busy the last several days and have just let things rest for the most part.Leave a comment:
What a great discussion, thanks Nap for that analysis, it is really interesting.
Silver, are you saying that your est and actual for Jan were pretty close? I didn't take the time to add up all the numbers from the individual days, does your meter give you a reading for that?
Just curious to know as I am still in the planning stage, and in East SD County which I believe has weather similar to yours.
Thanks!
[ATTACH=CONFIG]3697[/ATTACH]Leave a comment:
Thanks!
sun2.gifLeave a comment:
Ok, this is the last time I'll talk about this. Estimate is just an estimate. Please feel free to take a look of each screenshoot, and I hope you have a better idea what I'm say. They aren't really much different. Our vendor (bando and I) hasn't over sizing our systems. I know you don't like them, but please let it go....Leave a comment:
At the risk of breaking my word, I was looking at your Jan. stuff while composing a different rant 1-2 days ago to Bando and noticed how much your Jan. data overshot the est. like hers did, for what I believe is a month that I measured, in spite of what my gut, perception and sensibilities all tell me, as being not that much sunnier than normal. Can you post or P.M. the monthly data you have so far ? I'll ask the same of Bando if she ever talks to me again.
Thanks for the detailed cost layout, Naptown. It looks like the biggest part of the cost would be a structural engineering and drawing plan for $1200-$1500. I'm not sure if my installer ever did one. All I saw was a layout of where the panels go on the roof and where the inverters and boxes will be placed on the house. I also saw an electrical schematic drawn up for the system. But there was no paperwork seen for a structural drawing plan and nobody mentioned to me about having a structural study done on my house. So how do I know whether they spent the money on doing a structural study on my house or not?
Also, if this is an expansion of an already existing design, can't they reuse the original structural study (if they ever did one)? It doesn't make sense that this would have to be done twice. The structure of the house hasn't changed from before afterall, except for the original panels on the roof that were already approved anyway.Leave a comment:
