Snow removal
I never got used to wind chill factors of -30F. But some of us live in the "wild west", and
put up with a couple bad outdoor months each year, because we have a very long list of
reasons not to live most anywhere else.
This is the second winter, haven't lost a panel yet. Its very easy to periodically check on
a ground mount, with good sun & a clamp on DC ammeter. BruceLeave a comment:
Originally posted by SunEagleI understand. Hopefully all that frozen stuff doesn't hurt any of your panels.
5F today up there? Now I remember why I moved to sunny Florida. It got to 38F yesterday
morning which is a little cool for me but a whole lot better than below 32F.
I don't see any safe way to get the ice off. Its pretty thin, so keeping loose snow off helps
some sun get through. Not enough to melt ice at 5F, but should make at least 25 KWH today.
Not seriously worried; built my reserve in summer, don't have high expectations for Dec/Jan.
Bruce
5F today up there? Now I remember why I moved to sunny Florida. It got to 38F yesterday morning which is a little cool for me but a whole lot better than below 32F.Leave a comment:
Like Bruce said its effective up to about 4" of snow....more than that you need to use only one broom.Leave a comment:
Originally posted by DanS26Something like this..I just bolted three snow brooms together..cuts the time involved in half.
Still haven't gotten a combination of sun & temp that will melt the ice, Tues
looks like it will. Meantime have to settle for 4 or 5 KW. Bruce RoeLeave a comment:
Attached FilesLeave a comment:
There are three basic approaches to removing snow and ice from Solar Panel: mechanical, chemical, and thermal. It's not necessary to completely clean the solar panels, just get enough snow off so the dark surface can start absorbing light. The heat of the sun will do the rest.
I have my panels mounted on a tiltable array on the roof of my home, and in winter I set them to about 15 deg off vertical. Most of the snow here is light powder and thus the majority usually sloughs off. Sometimes the powder snow does stay on, and even if the majority of the snow does slough off, it is common for it to get hung up on the lower frame edge which protrudes (my panels are oriented horizontally length wise).
To clear residual snow, I made up a long (16 plus foot) handle and attached a t shaped brush to the handle. Just takes a few minutes to clear them. We don't get heavy wet snow here very often. Almost always light powder.Leave a comment:
If someone wanted to use fluid, I would suggest commercial deicing fluid used on airplanes. There a lot of similarities with solar panels. I expect if one could apply it at the top of the panels, it might break the bond between the panel and the snow which would accelerate the snow sliding off.
Generally the approach used in northern climates is mount the panels vertical and don't worry about snow. PV watts does take into account increased insolation from snow so the performance hit is not as bad as a vertical panel would model. Of course at 46 degrees latitude, vertical panels would be significantly impacted during the summer.
My wall mount array acts like an awning over an angle bay window. In the winter with a low sun angle the sun is low enough that the panels don't block it from entering the building but in the summer the windows are entirely shaded. It has made a noticeable difference in the temperature in the room with the window in summer to the point where even if the panels are not running I would probably leave them up. My set up was not designed for style, built out of unistrut and was added onto the house after it was built but I expect a similar concept could be cleaned up and integrated into the design of a new structure. I even have envisioned a vertical tracking component but expect the cost would far exceed the increased power gain. Of course this system is 10 years old and I seem to remember paying $6.50 per watts for the panels. Given the low cost for panels these days I expect having a summer roof array and a winter vertical array might start to make sense.Leave a comment:
Originally posted by Mike90250pump warm (not hot) water to a manifold tube at the top of the array ?
and wait. Lets see, 130' long, 12' high and deep, how to lift it and store it? BruceLeave a comment:
pump warm (not hot) water to a manifold tube at the top of the array ?Leave a comment:
I wouldn't try anything that isn't a great insulator. That may eliminate most. I spilled a bit of
sugar water (Coke) on an old keyboard, and I finally had to throw it out. Think I'll just be waiting
for a better combination of temp & sun.
I believe your panels are larger than any of mine. Bruce Roe
I wish there was a simple fluid that would keep the snow from sticking yet not harm the panel surface. Must make it hard to have solar in areas which gets lots of snow.
Hey maybe if the panels could be vibrated to some specific frequency that the snow wouldn't be able to stick. Sorry just thinking out of the box for a moment.Leave a comment:
