I think maybe I haven’t presented my problem in the right context. At my last home in Nevada, I designed and installed myself a ground based array with a Trace SW-4048 inverter. I had a 10kwh battery bank. If the power went out, and it did on a regular bases for days, the inverter could output its full 4kw to a separate sub panel that had all my critical circuits wired to. This included frig, freezers, minimal lighting etc. When I moved to Phoenix I also wanted the same functionality.
Obviously, now I’m 72, I’m not going to install my system like I did in Nevada but I want to be self reliant on power.
With that said, when I contracted to have a 8.8 kw system installed I requested the Sunnyboy 7.0 with the Secure Power option that will output 2 kw to a single duplex receptacle. Unfortunately the installer did not realize that option would not work with the required rapid shutdowd devices mounted on each panel.
So here I sit with 8.8 kw worth of power I can’t access in an extreme emergency. The installed blame’s the NEC and I’m in the middle.
I only want to provide for my family in a situation when power could be out for an extended period of time. In these times of uncertainty, you would want to do the same. Worrying about a house fire and safety of fireman would be my first priority in normal times. These are not normal times. When the sh*t hits the fan, the dynamics change dramatically. You might think the same.
SMA Sunnyboy Secure Power workaround for Rapid shutdown
Good point, That could be more serious than $500 of meat going bad, My suggestion to the OP is when the power goes out, invite all the neighbors over for a BBQ and maybe the neighbors will be so thankfule that they will feed his family so they won't starve,Last edited by Ampster; 04-18-2022, 06:35 AM.Leave a comment:
I wouldn’t remove the RS devices on the panels. I would either setup a fake 240 v injection into the main panel to simulate the grid hot with the main bkr open or simulate the “on” signal the inverter sends to the RS devices to again fake out the devices. Again, the system would first absolutely be separated from the grid to prevent back feed.Leave a comment:
No, they do not support SPS on their current inverters. I haven’t talked to them yet as during install, the installer hung on hold for 55 mins trying to talk to someone with another problem. Short on employees due to Covid etc. As far as the fireman on my roof, using the SPS would only happen in an absolute emergency in which I would have to be home to manually turn it on and could just as easily turn it off in the case of fire. How about all of the 1000’s of installed systems in the US that don’t have RS? Are you going to demand that they update their systems with expensive RS hardware? I think not.Leave a comment:
Things improve with time.
BobDude those 1000,s would be grandfathered just like when GFI or AFCI protected outlets became mandated in homes. Heck once upon a time you didn't even ground outlets. Doesn't mean you don't try and improve safety.Leave a comment:
Why would you want a fireman on your roof with 500+ DC volts near him? Great safety feature for the fireman. Better than the option LET IT BURN!!Leave a comment:
So, does SMA still officially support SPS in regions with RSS requirement?Leave a comment:
Has anyone figured out a work around the rapid shutdown problem that kills my inverters Secure Power Option? We all know the RSD adds very little in safety. Inverters are suppose to have anti-islanding per the code anyways. I understand that the RSS transmitter has to be powered up somehow to trigger the RSD devices on the panels to allow power to flow. SMA is silent on this due to liability. Yes, there has to be some common sense that the main panel has to be manually separated from the grid for safety purposes. I bought the Sunnyboy for the Secure Power option only to find out that this new rule of RSD torpedoed that. If the whole grid goes down due to foreign hackers in a war situation, who cares about RSD? I’m more worried about my $500 worth of meat in the freezer going bad and my family going hungry.
