Those multi throw switches commonly use rotary wafers, rated in mA. Getting something in DC voltage and amp ratings is going to be tough. You may have to make your own.
Diode steering might work, but you would loose power in the diodes (as heat, .7V 30A is 21 watts into a beefy heatsink)
Looking for DC switch
Where do I find a 3 DC Switches?
I’m looking for a DC switch for no more than 30 amps and max of 45 Volts DC just like this
This switch is made by Blue Sea https://www.bluesea.com/products/909...20_240V_AC_65A, but unfortunately its rated for AC Power, 65 Amps 120 / 240 volts.
I want to take a single input and send it to a choice of a 30 amp breaker or a 15 amp breaker. THe positions will be 15 AMps, 30 amps, off. This will all be whether my suitcase panels I attach to my RV are 4 in series for the lower Amp breaker, or in parallel for the night amp breaker.
I think the terminology of the switch is 3P4T (3 Position 4 THrow), but that’s not producing any DC results, if it shows the switch I want, rated for AC only.
