That was the way it was when I started doing phone office equipment. But they wanted stuff faster and more intelligent. You can't just make
stuff bigger, because electricity only travels 1' per nanosecond, wires need to be short. Office space is precious, and its really hard to put
heat sinks on 10,000 parts. So fans went in, but maintenance is available. Bruce Roe
Double the lifetime of an inverter?
Having designed industrial cooling systems for a living, and now having a window fan blowing up under my inverter for the last 2 1/2 yrs. or so, I'd suggest for a 5 -10 kW inverter in a garage, simple fan cooling will probably knock about 10 deg .C. out of a 30 deg.C. heat sink to amb. air delta T., and probably not cause enough additional fouling of the heat transfer surface to be of any concern. In my ignorance, whether or not an inverter running 10 C. cooler lasts longer Is something I'm ignorant about. I'm guessing it won't shorten the life. The additional cooling costs more in energy to run the fan than it removes from the heat sink for my application. It's probably not cost effective. Whether or not it helps or harms the equipment is unknown to me. I'm working on the belief that heat does more harm to electronics than cool. The fan fires up ~ 0600 and runs until about 1/2 hr. after the inverter shuts down, or when I get to it. That probably takes care of time/temp. thermal shocks. None of this is rocket science. I've no idea if an inverter running 10 C. cooler lasts longer or not, but I'm having fun.Leave a comment:
Using Fans to cool electronics indicates a thermal management problem, and fans are the poorest choice you can make, but the least expensive. The issue with fans is they are high failure rate devices, dust/dirt magnets which only compounds thermal runaway problems and makes it worse.
upping the speed of the remaining fans as needed. And filters get regular maintenance. Bruce RoeLeave a comment:
Using Fans to cool electronics indicates a thermal management problem, and fans are the poorest choice you can make, but the least expensive. The issue with fans is they are high failure rate devices, dust/dirt magnets which only compounds thermal runaway problems and makes it worse.Leave a comment:
Actually, commercial parts are rate 0 to 70C, industrial grade -40C to 85C and military -55 to 125C.
They're mostly the same parts, made the same way, just screened (tested) to different levels. The mil and space parts are usually hermetically sealed.
Does SMA have a military division?
I don't care if you're an iPhone fan or android. In any case, one has to admit the smart phone is highly engineered and a marvel. -
Where's the data to back that statement up? I've provided you data, where's yours?
The contractor made several fixes to the design and I got a replacement. The fan barely turned over at low power levels, and didn't go to higher speeds until temperatures rose. (Thus, overall, temperatures were higher - at least at first.) It worked well for me for years before I moved. It was far more reliable, and the fins stayed much cleaner.
The original designer took a simplistic approach - "low temperatures are always better so run those fans." The result was lower reliability overall. Good electronic design is considerably more complex than "just run the fans to make the inverter cooler and it will be more reliable."
Sure, for a space (or some military) job the development would be upscaled and the components would be tested to death to weed out any infant moralities but would it be any more reliable over the long haul? Doubtful. Electrolytic caps are not allowed in space applications. Tantalums (except for wet) are frowned upon, it's mostly all ceramic now, so they would most likely increase board space and load it up with ceramics. Barring that, I'd put my money on any SE or SMA inverter to outlast a military unit.Leave a comment:
Do you think they could produce a more reliable inverter (or cell phone) than SMA (or Apple)? I think not.Leave a comment:
... or they might result in 1/4th, 1/8th or 1/16th! Where's the beef? Where's the data to back that statement up? I've provided you data, where's yours?
I'm tired of this and have better things to do with my time. You once stated that you believe that (at least) capacitor lifetime follows Arrehius. Now apparently you don't.
I'm just trying to help extend inverter lifetime for anyone interested. I'm taking data and installing small fans. Anyone else can do what they want.Last edited by DaveDE2; 06-14-2016, 08:52 PM. -
Sunking, I get what you're driving at too but I don't understand the logic.
This new SMA inverter (6.0) is the most highly engineered thing I've ever seen excepting an iPhone. It must have hundreds of thousands of engineering hours poured into it, a culmination of 20 years of innovation by dozens of engineers. On the other extreme, a military inverter (if not actually produced by a mfg like SMA or SE for the govmt) is in comparison likely a hack job produced from scratch with a limited govt budget by some contractor such as Lockheed or Raytheon for a specific application with probably a team of five to ten or so engineers within 2-5 years, etc. Do you think they could produce a more reliable inverter (or cell phone) than SMA (or Apple)? I think not.
Sure, for a space (or some military) job the development would be upscaled and the components would be tested to death to weed out any infant moralities but would it be any more reliable over the long haul? Doubtful. Electrolytic caps are not allowed in space applications. Tantalums (except for wet) are frowned upon, it's mostly all ceramic now, so they would most likely increase board space and load it up with ceramics. Barring that, I'd put my money on any SE or SMA inverter to outlast a military unit. -
Dave I understand what you are driving at. But today is a very competitive market which forces manufactures to take short cuts, and use loose tolerance components.
Go back to the 50's and use electric fans as an example. Most still work today because they are built like tanks. You might have to replace the Cotton/Asbestos power cord, but mechanically they are tough. Hell even the ole Western Electric Rotary dial phones still work if you can find them.
Today you have four grades of product quality. Consumer, Commercial, Industrial, and Military. You as a consumer can buy any grade you want. Most likely you will buy the 4000 watt $2000 Consumer grade Grid Tied Inverter vs the $6000 Industrial grade model, or $10,000 GI Joe model.Last edited by Sunking; 06-14-2016, 05:35 PM.Leave a comment:
