SunPower with SolarEdge or SMA - OR - SolarEdge with Other Panel ???
This thread is a bit old so gsxmike might no be around much anymore. You should be aware that there are those who lurk on the forum trying to get people to buy from the installer they used as they get a referral fee, much better off doing your own homework.
A good place to start is by using the services of our site sponsors, www.solarreviews.com enter your zip code and or www.solar-estimate.org that one spits out a rough quote and an installer will call or email to go over in more detail.
Read up on solar there is a lot of good info to sift through here, understand that conservation is the best and most cost effective way to reduce your electricity bill, you might want to try googling solar for dummies apparently there is a free version of this online somewhere and its good for beginners to get a clue on how solar works.Leave a comment:
Please PM installer
Wow, that's quite impressive. Many thanks for the amount of detail in your post, and for opening my eyes to looking elsewhere besides SunPower.
I just received the following quotes from one of the most reputable installers here in So Cal:
Option A: SolarEdge 7600 Inverter, P400 Optimizers, 25 year warranty on the Inverter, Wi-Fi monitoring, with 24 SunPower 327 watt panels for $36,000. That's a 7.85kWh system, for $4.58/watt.
Option B: Same inverter setup (w/P300 Optimizers) with 26 LG300 panels (7.8kWh system) for $26,500 (that's $3.39/watt)
Option C: Same inverter setup (w/P300 Optimizers) with 28 LG300 panels (8.4kWh system) for $28,420 (that's $3.38/watt)
In addition, this is from one of the most reputable installers here in So Cal. Thoughts?
I'm in the market for a poweredge system in that price range. Gsxrmike, would you mind PM'ing me with your installer's information?
ThanksLeave a comment:
Would you mind PM me the installer info (can't PM you too few posts)? I was quoted $25-26.5k for a 20 panel LG300 system (6.1kW, but with Enphase Microinverters) which amounts to $4.1 to 4.41/W.
Thank you very much,
KayLeave a comment:
Sounds good to me
Would you mind PM'ing me the companies that you worked with for the quotes on the above? I am live in northern SD county and am looking for a 10kW system.
Thanks,
PowayLeave a comment:
I recently installed both on my commercial bldg. and home over 200 Sunpower X20-327 panels with Solaredge optimizers and Solar Edge inverters.
Could not be any happier with the system.
PM for my installer contact if you need help.
My home system is 38 panels X20-327 with SM6000A inverters (2 of them).
YTD my system has made 3,000KWH excess and I have had a $0.00 bill down from $550 avg.
Very happy to say the least.
TMLeave a comment:
LouiA
Problem being 29 Sunpower panels do not string with an SMA 7000 inverter. 24 would work if strung properly.Leave a comment:
GSXRMike,
Would you mind PM'ing me the companies that you worked with for the quotes on the above? I am live in northern SD county and am scoping a very similar sized system.
Only received 1 quote for 29 SunPowered 327 panels with an SMA7000 inverter for $34K. That is a bit pricey in my book.
Best,
LouieALeave a comment:
YTD my system has made 3,000KWH excess and I have had a $0.00 bill down from $550 avg.!!
TM
Thanks!Leave a comment:
Best,
