I did a composition shingle inlay on a self install ten years ago. If there is sufficient slope comp shingles can provide effective waterproofing and accomodate typical flashing for attachments. There are many pros and cons. I am sure there will be those that differ. It may depend on aethetics.
One of the drivers for me was I already had some broken tiles and finding replacements that matched was going to be expensive.
Solar panel installation on Spanish clay tile roof - floating tile hook vs comp out?
Hi all,
I’m in a bit of dilemma trying to figure out which way to go (and company to go with) for a solar panel install. I’ve gotten close to a dozen quotes/opinions from solar installers and roofers. Only two of those contractors have suggested the tile hook method (not the kind where the hooks would be mounted to the tiles but rather the kind where the hooks are mounted to the decking/rafters). The rest have all been adamant that comp out inlay is the best way to do it. Even my own roofer, who did an underlayment & membrane repair for the prior owners a couple years ago AND replaced a bunch of broken Spanish clay tiles, advised that I should just do a comp out.
It seems there are very obviously two camps and drastically different opinions on either method - I’ve heard some pros and cons to both.
At the end of the day, I just don’t want for there to be any leaks in the roof!
What would you guys suggest in this case?
