Some others here are most likely better able to comment on the specifics of your electrical details. I'm experienced enough to have rewired my first house and passed inspection, designed control logic for power and process systems and designed my own string inverter system using KISS principles and the installer's help/comment on the stringing/wiring, but without a lot more details of what you have in mind, and without being there, I don't feel comfortable enough to comment on specific electrical or control matters for PV arrays without writing something that may well wind up being unsafe. On engineering or technical matters, I've always tried very hard to stick to areas of my technical competence. Being an M.E., I bet you can appreciate my opinions on such matters.
FWIW, I have 1 J-box and it's attached to the roof. I didn't specify the mfg. - I left that choice to the installer. I did specify a NEMA 4-X box, and that it be tucked up under the array out of direct sunlight, positioned so as to be readily and easily accessible for /inspection/service, but I've got ~ 12 " or so clearance between roof deck and bottom of array.
More FWIW, I ran the whole design past the AHJ/inspector who does most of the inspections in my HOA before I went for permitting.
As I wrote in my first post to this thread, I'd just be skeptical of the answers I got until I understood them. None of us is as smart as all of us, but some of us aren't as knowledgeable as we might think, probably including me. Unvetted information from autonomous sources is free. You get what you pay for, or less.
Most Popular Content
New Memeber and Starting New Project
Don't know if it was mentioned yet (may not apply in your area) but grid-tie rules here prevented us from installing more capacity than we needed. They looked at our past power bills and would only approve us to co-generate that same amount or a small percentage over. My home insurance company also had an issue with a PV system that produces more than we consume. They said any residential customer over-producing by more than 25% in any given month is considered a business (because excess is sold at wholesale value). If there was a damage claim on the solar system they would deny any coverage. I changed insurance companies to fix that problem. With kids moved out we now over-produce heavily in some months (231%) is the max.
Hey mind if I bounce one more thing off you? Starting to struggle with the last details of my system and I just want to make sure all my bases are covered because I'm getting the feeling I'm running in circles. I'm trying to understand the electrical aspect of this so I can get the last few pieces I think I need. So far my situation is;
30 panels - which are connected in 3 strings of 10 panels requiring 5 grounds. These will be connected into 3 different junction boxes (4in x 4in, type unknown). I assume the junction boxes can't float in the air, and you probably don't bolt them to the roof...so do they usually attach to the rails? Any chance you have an idea who might make a good junction box that has provisions for attaching to the rails? I also have a TON of PV wire, is there anything that says you can't run from the optimizers right to the inverter using PV wire?Leave a comment:
Fair enough, I've been on the horn with them a bunch but one more call to make sure all the ducks are in a row probably won't hurt. Thanks JPMLeave a comment:
No. I'm ~ 35 miles north of the San Diego airport.Thanks, I think you mentioned you're in Florida right? I'm installing near Tampa and just got a rough in scheduled for tomorrow and have been trying to figure out what's going to happen since so far it's seemed way too easy. I received an electrical permit (and provided an NOC), was given a clear to start and installed the mounting (they're products that are new to the U.S. market and don't have official PE stamped span tables). The county hasn't requested any documentation on the products I'm using or the 3 PE stamped drawing sets. Are those supposed to be turned in to receive the permit, or do they review them at rough in if you know? Just want to make sure that when the inspector comes he doesn't decide he's never going to let me pass, ya know?
I'm somewhat familiar w/ Tampa/St. Pete area w/ many good friends there (or no longer there), but I'm unfamiliar w/local practice/custom/requirements w/respect to doc. review/inspections.
Seems like you have nothing to lose and lots of potential gain w/ a phone call or 2. If it was me, I'd give them a buzz. Got nothing to lose and potentially a lot to gain.
Somewhat analogous to a deal that seems too good to be true, a project or portion of one that seems too easy probably has something missing that, like the big chunks in a cesspool, will eventually float to the top.Leave a comment:
Thanks, I think you mentioned you're in Florida right? I'm installing near Tampa and just got a rough in scheduled for tomorrow and have been trying to figure out what's going to happen since so far it's seemed way too easy. I received an electrical permit (and provided an NOC), was given a clear to start and installed the mounting (they're products that are new to the U.S. market and don't have official PE stamped span tables). The county hasn't requested any documentation on the products I'm using or the 3 PE stamped drawing sets. Are those supposed to be turned in to receive the permit, or do they review them at rough in if you know? Just want to make sure that when the inspector comes he doesn't decide he's never going to let me pass, ya know?Leave a comment:
Understood. Canadian solar is good stuff. More than a few in my HOA. No bifacials however.I see, that's a lot of information, I hadn't considered the effect the glass back would have. The loss due to temp. increase I suppose could happen but I imagine it's small to negligible.
The panels I bought were CSU-385-MB-AG, were about $170 a piece and came on the original Canadian Solar pallet. Could be commercial left overs, but my guess is they were intended for a residential ground mount system. Either way, the way I saw it is I'd be happy paying what I did for a 385w tier 1 panel - the manufacturer has a good reputation and they're not someone you'll have to worry about going out of business. The roof will be loaded up on panels and should do 11.6 kW so if there's no increase in production from the backside it's alright with me...if I do get some, even better.
Good luck.Leave a comment:
The panels I bought were CSU-385-MB-AG, were about $170 a piece and came on the original Canadian Solar pallet. Could be commercial left overs, but my guess is they were intended for a residential ground mount system. Either way, the way I saw it is I'd be happy paying what I did for a 385w tier 1 panel - the manufacturer has a good reputation and they're not someone you'll have to worry about going out of business. The roof will be loaded up on panels and should do 11.6 kW so if there's no increase in production from the backside it's alright with me...if I do get some, even better.Leave a comment:
Good questions.Good info to know, the distributor said close to the same thing, that the panels are better ground mounted due to the irradiance (roof gain would be roughly 5% rather than the 15~30 you could see ground mounted). But that leads me to a question, if any gain is to be had at all with roof mounting a bifacial will it be close to sunrise/sunset or is the panel itself is mildly transparent? But why would the operating temperature of the panel go up if the back side gain is zero? You'd think that relative to a standard panel they'd have the same production since the backside gain is zero? As the sun gets closer to sunset/sunrise I could see where this can become a bit of a differential equation where I certainly don't have enough info. Wanted to paint the roof white but figured that's just too much
But first, and believe what you want from someone with no skin in the game vs. a distributor, but with/for a roof mount w/common residential application and with ~ 15 cm or less clearance off the roof deck, you'll be lucky to be able to measure any increased production much less 5%.
That 15-30 % number is what he's read in the greenwash media or mfg. phony crap. It's a B.S. statement without the qualifiers that most people wearing rose colored glasses, or conmen leave out because they are either clueless about what they're spouting off about, or are trying to take advantage of the solar ignorance of the person they're trying to sell some something to, or repeating what they read/heard or otherwise acquired to make someone else think they know what they're talking about. Either or any way, it's all B.S. As I suggested in my first post to this thread, be skeptical. (That caveat, BTW, includes what follows below. It's all opinion.)
That distributor's comment might have been more accurate if he'd used 0% instead of 5% gain for a common roof mount. With a ground mount, unless you have a high tilt like > 30 deg. or more, which is usually unlikely in FL, and/or unless you're way off south for an azimuth with a high tilt, and/or you're array is high enough to drive under (like a carport or parking lot PV) and is located over a light colored/concrete surface with no adjoining shade and very light colored and reflective surroundings, you might get 10 % or so enhancement on a very sunny day, but lots less otherwise. A mostly south facing residential ground mount with an at latitude tilt a few feet (like 1m or less maybe) off a grass surface, which is probably a more realistic residential scenario, might get close to 5 % on a sunny day, but I'd kind of doubt it would be that much on an annual basis.
Then there's the consideration of how to mechanically support a bifacial panel using common racking. Common rooftop racking has 2 rails running across the back of a row or in any case rails that are great for support, but also real good at blocking sunlight. Up shot: You may run into some mounting situations and associated costs that may chew into the great deal you got on those panels.
Lots of studies on bifacials. Every one I've seen has dealt with the case of commercial installations or potential applications that use (usually single axis) tracking. None for residential. I'm not surprised. To anyone who has ever looked under an array up close under the midday sun it's a blinding flash of the obvious no brainer that there's hardly enough light under there to see anything at all much less generate power. Maybe that no light factoid has something to do with the dearth of studies for bifacial rooftop arrays. All the "studies" and White paper" stuff from outfits with skin in the came are, IMO only, pretty obviously self serving. The serious academic stuff in the journals and from outfits like NREL are all for commercial size installations and mostly single axis tracking arrays. Even a few (but by no means all) articles from the usually biased greenwash media and solar fanboy outfits say bifacials are great for commercial installs, but not ready for primetime residential at this time.
Can you provide a bit more about the panels you bought ? I'm not a fearmonger by nature but I wonder if you got a "deal" on what might be sloppy seconds or excess left over from some commercial installation. Not a dig at you, but if so, it wouldn't be the first time some peddler took advantage of someone's solar ignorance.
As for gains at sunrise/sunset:
Even with a panel oriented normal to the sun at such times, the irradiance is so low at those times, the times so short, and for short times of the year around the summer solstice for a total of a couple of months or so that it makes little, if any difference in annual output.
Bottom line: For a commonly oriented panel the gains at sunrise/sunset are about nil.
More reasons: For common orientations, the small amount of irradiance on the backside of a panel at such times is much less, that is, approx. as the cos(angle of incidence of beam radiation on the surface) which is usually > 70 deg. or so on the backside of a commonly oriented panel.
Common roof mounted array orientations don't see much of any direct backside irradiation except maybe around the summer solstice and then mostly in the higher latitudes. In FL, you will see even less.
Then there's the increase in reflection of glass as f(incidence angle). At, say 70 deg. A.O.I., even what's called non reflective glass will reflect ~ 40 % of the already small amount of radiation incident upon it, and even less yet as f(wavelength of light) in the shorter wavelengths of light useful for silicon devices such as solar panels.
The cell efficiency of a double sided panel will probably decrease because the operating temp. of the panel will increase.
Reason: Many if not most single face panels have a white backing that serves 2 purposes. First, it reflects some of the irradiance that made it through the cell back to the cell. Second, it serves as a reflector for the backside to help keep panel temps. lower than they otherwise would be for any (small) amount of incident albedo that may get to the backside of a panel.
Bi-facials have a dark back. But in a std. roof mount orientation, because the back side sees little to zero radiant energy from just about anywhere, direct, diffuse reflected, albedo, whatever, , that dark color isn't what causes the potential temp. increase in a bifacial vs. a monofacial panel. (But note that black backed mono panels generally have lower efficiencies than otherwise identical white backed panels).
In the end, what will increase temps. more for a bifacial is the glazing on the back side. It's glass and glass reflects infrared thermal radiation - that's why windows work as well as they do.
Here's the deal: A single face panel usually has poly backing. That poly backing is a lousy insulator. That's good because the back of a panel is one of the two big surfaces (the other is the front side) that lose the heat the panel absorbs from sitting in the sun that doesn't get turned into electricity. Now, put glass over that (back) surface. The panel will now have a lower overall heat transfer coeff. because the added glass is a better insulator than monofacial panel's poly backing. Since the irradiation (solar energy input) is the same for either panel, mono or bifacial, the temp. of the panel with the lower heat trans. coeff. must go up to maintain the energy balance on the panel. Result: To a first approx., a heat/energy balance on the panels will show the bi facial panel will lose less heat per degree of temp. diff. between the surroundings and the panel. That means the bifacial panel/cell temp. must go up to maintain the energy balance on the panel. Higher cell temps. mean lower efficiency. How much ? Run an energy balance on two panels and find out.
Note: That's an approx. based on a heat balance and heat transfer characteristics. As a secondary consideration, if for no other reason that if the panel temp. goes up, the efficiency will drop, more irradiance will go into panel heat generation. That will raise the panel temps even more, but that's not a consideration for this discussion.
At this time I believe the powers that be have not standardized on a method to do an S.T.C. testing on bifacials. I suspect that process is complicated in that most to effectively all of the irradiance on the backside of a mostly equator facing panel will be :
1.) Diffuse
2.) Highly site dependent with respect to direction, intensity and wavelength.
3.) Highly dependent on panel orientation.
Those and other factors will make even meaningful definition of Standard Test Conditions a challenge.
Thanks Mike, according to the codes here it is not allowed to be mounted to an exterior wall or overhang the roof...I'll admit I didn't know about the setback until after I ordered the panels and drew up plans...that would have been a real problem
Rapid shutdown is another issue. I'm NEC 2017 compliant but I think someone has said they wanted an AC disconnect...but that needs to be clarified with the inspector since I believe my inverter shuts down the optimizers if grid voltage goes below a certain threshhold. It's on the list of questions I have for him but I always appreciate inputLeave a comment:
I have not seen any practical explanation of how the bifacial panels can be significantly beneficial. Too
bad because I might have a good ap. But even my original panels are somewhat bifacial, so what?
Bruce RoeLeave a comment:
Good info to know, the distributor said close to the same thing, that the panels are better ground mounted due to the irradiance (roof gain would be roughly 5% rather than the 15~30 you could see ground mounted). But that leads me to a question, if any gain is to be had at all with roof mounting a bifacial will it be close to sunrise/sunset or is the panel itself is mildly transparent? But why would the operating temperature of the panel go up if the back side gain is zero? You'd think that relative to a standard panel they'd have the same production since the backside gain is zero? As the sun gets closer to sunset/sunrise I could see where this can become a bit of a differential equation where I certainly don't have enough info. Wanted to paint the roof white but figured that's just too muchLeave a comment:
Another DIY gotcha is the Roof Setback for isles for firefighters.
Specifically ask the building department what the setback requirements are (if any) and if you need Rapid Shutdown in your area. Rapid shutdown requirements may alter the electrical plan significantly.Leave a comment:
You're welcome.Thanks JPM , I really appreciate your suggestions and your willingness to help me out, I know I'm probably one of a thousand different stories like this. Ultimately, after going through all this, I really hope I'm able to serve as a resource for people in my area who want to do the install themselves but don't know what they need to know or how to navigate these unfamiliar waters. Part of the want to DIY this is I've met several installers who are glorified snake oil salesmen who want to sell you anything and everything and it's frustrating that they're still in business.
I did decide to reduce the power of the system to 11.6kW due to the tier 1/tier 2 requirements (in my area they allow a 10kW system is allowed to be oversized by 1.7x to make up for inefficiencies so 11.7 is the cutoff for tier 1/tier 2). The panels I'm using are 385w bifacial and may produce up to 410w with the reverse side gain. I suppose that might need to be considered when going through the electrical...
Have also been talking with the building department, the inspector who'll be in charge, and received a permit/all clear to start but still waiting on records to record the Notice of Commencement so the rough in inspection can be scheduled. I have installed flashing-style mounts but that's as far as I'll be going. One of my concerns is the permit was issued before the building department received any drawings or spec sheets of my components...but they know what they're doing and if anything comes up it's "Yes mister inspector sir, I'll fix it exactly like you said/get that to you right away sir." Like you said for a project like this they are the last person you want to make your enemy.
For the most part I'm pretty stubborn about having more solar than I need because I want some breathing room and intend to have a business out of my home eventually and want the extra electricity for a computer/server, but that's down the line.
Found a pdf copy of the book so I'll be going through that over the next few days. Thanks once again for all the suggestions and looking forward to being a part of all this and being able to help someone in my shoes in the future
Understood. One example of putting the knowledge cart before the horse and also maybe snake oil salespeople: If you are planning on a roof mount with the array(s) with an orientation parallel to the roof they're mounted on with something like a 15 cm. or so stand off from the roof deck, know that because the irradiance at most any time and also the daylong insolation reaching the backside of a panel will be close to zero, for a lot of reasons that's about what you can expect for a production contribution from the backside of a bifacial panel. Ground mounts fare a bit better in terms of backside contribution but because peddlers usually quote specious studies and use circular references and logic as well as using "up to" numbers for backside contribution, I wouldn't count on much from the backside of a panel. They might even hurt overall production a bit by lowering the overall panel's efficiency due to increased operating temps. as a result of a lower overall heat transfer coeff. from the panel to the surroundings.Leave a comment:
